I've been contemplating several lighting mods to increase conspicuity. I was working them off one at a time but decided to step back and do them all at once. Some electronics will be required so rather than piecemealing it, I am going to design and build a centralized control unit for all of it that I mount in the glove box (likely).
Here's my desired requirements:
- Flasher switch that winks all turn indicators on/off when the flasher switch is on and the key is on or off. The flasher switch must be in the glovebox to avoid tampering
- Side running LED lights that are on solid when the turn signal indicator is off and key is on; appropriate side winks on/off when the turn signal is engaged; and winks on/off when the flasher switch is on whether the key is in the on or off position
- Auxiliary tail lights that have the same functionality as the tail light when the flasher switch is off; winks on/off when the flasher switch is on and the key is off. If two lights are used (like I envision by moding the top case reflectors), the appropriate side should wink on/off when the turn signal is engaged and the flasher switch is off.
- Mechanical clicking sound that indcates the blinker or flasher is on that can be heard at speed
Anything else you'd desire?
Thx
Miguel
