@rick_v avatar
1974 Rally, 1978 P200E, 2000 HD Fat Boy. 2007 HD Street Glide
@rick_v avatar
Anyone know of any available horn for a 74 Rally 200 Im restoring? I dont know bumkiss about electronics so Im assuming, since it was a battery bike before, and 6 volt, it was a DC horn originally? Now I have had it converted to 12 volt so Im again assuming its AC now??
Any advice would be appreciated. Too bad really because the original horn was quite loud.
Rick
@slick_89 avatar
1971 Sprint with P200e
@slick_89 avatar
I'm still using the same 6v horn now I've converted to 12v (non battery).
That said, it does sound like a gay squeezy toy, so I avoid using it, I just shout, nod, wink.........or hoof car doors in with my feet.
@rover_eric avatar
@rover_eric avatar
Re: Horn for 12 volt conversion?
Well..that all depends.
Did you just put 12v coils in the stator, or did you switch it out entirely for a new stator / flywheel combo that is a 12v ducati-based electronic ignition kit?
Either way, you're likely running a new regulator / rectifier since the original was 6v.
Are you still running a battery ?
vespa sprint veloce p210
Rick-
If you have converted to a 12v system and you are using a battery, then you are looking for a DC horn. I ran into the same trouble as you when I did the same, here's my solution...
I went custom because I was tired of the whimpy stock horn sound. I bought a Wolo horn from amazon, you can find them everywhere. You can get them for cheaper.
http://www.amazon.com/gp/product/B00029XGNM
I dissassembled it, took out the guts and slapped it into the stock cover plate and somehow secured it with screws. It took 15 minutes and a little trickery because it was shorting out on me.
Loud and cheap, sounds like someone I would hate, but its a solid horn.
Porter
[ Time: 0.0105s ][ Queries: 3 (0.0032s) ][ live ][ 343 ][ ThingOne ]
