Hi all,
I bought my daughter an ET4 50cc for her 16th birthday. Low mileage and stored in a shed for a few years (after the owner fell off).
Fitted a new battery, new spark plug, cleaned out the carburettor and got it started easily enough but have a severe problem with lack of power.
The scooter starts fine and will pull away sharply. Once it gets up to about 15mph it kind of stutters and does not pull at all well.
On a flat road it will gradually accelerate up to 30-33mph but as soon as it encounters a slight rise it slows to 20-22mph. Going up hill it will only manage about 15-17mph.
I expected it to be slow but it is more than that, I can feel somethiong is wrong but not sure what.
I have a spark and it runs so I'm assuming the coil is ok.
I've checked the vacuum pipe, sucked on the small pipe and petrol came out of the other one.
Carburettor float bowl has clean fuel in it.
The plastic cover on top of the carburettor (over the rubber diaphragm) was cracked so I replaced the whole carburettor with one I know was good (made no difference).
Took it to a local scooter specialist who had it for a while and then said 'There is something major wrong with the engine!. It did not generate enough power to even get his rolling road turning! He didn't want to take on the job of fixing it as he 'specialises' in two strokes. In fact he suggested I 'convert it to a two stroke' as they are 'much better!'.
I'm stuck now!
Apart from trying to source another engine.
Does any of this ring any bells with anyone?
Any help will be most gratefully received.
Anthony
