If you have a side car on a GTS 250 or 300 can you please post some pictues and let me know if your happy with it.
2015 Sprint 150 ABS Yellow. 1974 Vespa Rally 200 White, non battery model.
Posts: 2304 Location: Austin, Tx |
Re: Sidecar
175mws wrote: If you have a side car on a GTS 250 or 300 can you please post some pictues and let me know if your happy with it. It was their first Vespa to work on and they were sooo eager to do it!! Turned out great: http://www.texassidecars.com/vespa.htm |
GTS 300ABS, Buddy Kick 125
Posts: 13563 Location: Oregon City, OR |
ServiceJeff wrote: www.vepsastl.com I had a blast riding this one! |
RIP
Curt Fargo had one. Don't remember which scooter he had it on. There should be some pics on here somewhere.He doesn't post much anymore. Might find a pic if you do a search.
Posts: 3733 Location: Babcock Ranch, Florida |
Now riding a P200 with a sidecar I would have two questions:
1) How much cutting, welding, and drilling is necessary to mount the car? How much plastic do you have to cut? 2) How does pulling the (considerable) extra load affect the CVT? It takes a fair amount of slipping the clutch to get that thing started with a passenger in the car. That's OK with a real clutch and gears, but I don't know enough about the CVT to know whether it will do the job or burn up (I also ride a LX150 regularly). I kind of feel that the new T&G bikes may be less suited to a car. |
judy wrote: Curt Fargo had one. Don't remember which scooter he had it on. There should be some pics on here somewhere.He doesn't post much anymore. Might find a pic if you do a search. |
RIP
Tor2ga wrote: Now riding a P200 with a sidecar I would have two questions: 1) How much cutting, welding, and drilling is necessary to mount the car? How much plastic do you have to cut? 2) How does pulling the (considerable) extra load affect the CVT? It takes a fair amount of slipping the clutch to get that thing started with a passenger in the car. That's OK with a real clutch and gears, but I don't know enough about the CVT to know whether it will do the job or burn up (I also ride a LX150 regularly). I kind of feel that the new T&G bikes may be less suited to a car. |
Their website doesn't have good pictures. I emailed and got higher res pictures...I downsized to fit here...
S 150, VNB 150, 101 Allstate, 01 ET2, 2005 PX
Posts: 1504 Location: CT |
I wonder what they have to do to the GT/GTS to make it handle okay with all that addl weight alongside?
Most motorcycle sidecar rigs have special adjustments made to the steering (a damper) and also to the frame and front suspension, sometimes even converting to a "leading link" type of hookup just so it can be driven adequately! But even so, the handling on a sidecar rig is TOTALLY different! Left turns require lifting the car sometimes with a countersteer maneuver, and a right turn requires a bit of muscle at the handlebars to correct oversteer as it usually turns in sharply! Also the rig generally wants to turn alla time of it's own accord, and so requires extra muscle on the bars to keep it just going straight... And I would think having smaller wheels on a sidecar rig would make it even more tricky to handle? Even more prone to slip into unwanted turns and slides? I dunno; -anyone with experience driving one? (And yes, I think "driving" is the operative word here...) |
Chazzlee wrote: I wonder what they have to do to the GT/GTS to make it handle okay with all that addl weight alongside? Most motorcycle sidecar rigs have special adjustments made to the steering (a damper) and also to the frame and front suspension, sometimes even converting to a "leading link" type of hookup just so it can be driven adequately! But even so, the handling on a sidecar rig is TOTALLY different! Left turns require lifting the car sometimes with a countersteer maneuver, and a right turn requires a bit of muscle at the handlebars to correct oversteer as it usually turns in sharply! Also the rig generally wants to turn alla time of it's own accord, and so requires extra muscle on the bars to keep it just going straight... And I would think having smaller wheels on a sidecar rig would make it even more tricky to handle? Even more prone to slip into unwanted turns and slides? I dunno; -anyone with experience driving one? (And yes, I think "driving" is the operative word here...) There are a couple of good books about this. The physics are not intuitive. |
RIP
from what curt said it handles way different. Very unstable in certain conditions. I wish he was on here since he'd be the perfect person to answer all your questions.
Hello
louisq wrote: Their website doesn't have good pictures. I emailed and got higher res pictures...I downsized to fit here... this one looks much better then the COZY Sidecars I have seen until now. good thing is that they are cheap enough for a first try with no help here.รง Would be the first Vespa with Sidecar in Chile I guess. Well, would be great to have some more information about this one.
this is the cosy sidecar, doesnt look to bad
Chazzlee wrote: I wonder what they have to do to the GT/GTS to make it handle okay with all that addl weight alongside? Most motorcycle sidecar rigs have special adjustments made to the steering (a damper) and also to the frame and front suspension, sometimes even converting to a "leading link" type of hookup just so it can be driven adequately! But even so, the handling on a sidecar rig is TOTALLY different! Left turns require lifting the car sometimes with a countersteer maneuver, and a right turn requires a bit of muscle at the handlebars to correct oversteer as it usually turns in sharply! Also the rig generally wants to turn alla time of it's own accord, and so requires extra muscle on the bars to keep it just going straight... And I would think having smaller wheels on a sidecar rig would make it even more tricky to handle? Even more prone to slip into unwanted turns and slides? I dunno; -anyone with experience driving one? (And yes, I think "driving" is the operative word here...) As you might suspect, It's a whole new 'ballgame' from riding a two-wheeler, essentially the addition of a sidecar makes it an entirely different vehicle. What Tor2ga said about the behavior of the rig is right, and I will add that under acceleration, the (right sided) rig tends to pull right from the off-centered drag of the car, and when braking, the the inertia of the car tends to push the rig left. All this is compensated for at the handlebars and must be anticipated. As mentioned before, right turns could be quite disconcerting with an empty car and although I would often ride mine without any additional car ballast, a freeway cloverleaf could make you pucker, though a left turn was a relative piece of cake, empty or not. Another thing to keep in mind is to NOT forget that there is a sidecar hanging off the right side of the bike....meaning that you must ride with the bike in the left tire lane of a road or risk an unscheduled sidecar de-installation with the help of a parked car by the curbside. Sounds like a no-brainer, but it has happened. Riding a sidecar rig in a stiff crosswind is great for building up your arm muscles. |
RIP
Posts: 8291 Location: Latina (Italy) |
