But there is another problem. My new battery loses its charge over a number of days.
My question is are the two things related?
The ground wire seems burned up. Does it carry a heavy current load at shut down?
How much hassle is it to change the wiring harness? Do I have to disassemble the whole thing or is it pretty much just a connection issue?
The gas tank removal is trivial, and I have pull cords through the chassis to pull wiring, so should I attack the whole harness or just the ground wire?
First I couldn't keep it running, now I can't make it stop.
