Sorry if this sounds like a rant. At 12k miles the speedo on my GT failed and was replaced under warranty.
Now a few years down the line the tracking on the back of the replacement has failed. I only found out what tracking was twenty mins ago - the copper wiring that runs around the plastic film at the back of the speedo that carries the current to the bulbs and clock.
This means that while the rest of the unit is in perfect working order, one indicator lamp on the dash for the left turn signal is failing to illuminate. In the UK this is an MOT failure. Cost of fix - £131 for a whole new dash pod - and that's if I fit it myself.
To top it off the Piaggio Customer service number is no longer active and there are no second hand dash pods on ebay.
I suppose it's the sort of problem you just have to deal with when you own a five year old scooter.
Thoughts/advice much appreciated!
David
