Fri, 15 Sep 2006 16:40:39 +0000
ET4
ET4
Fri, 15 Sep 2006 16:40:39 +0000 quote
Our 2006 GT200 (still under warranty) is in the Vespa dealer's shop because it is making a loud grinding noise upon acceleration. I have read through all the old posts here about this, but am not getting any satisfaction from the service department.
The tech in the shop is using the famous "cannot be duplicated" line. We explained that the problem starts after the bike has been ridden for a bit, and a 5 minute test drive probably isn't going to do it.
Any ideas on how to deal with the service department on this? The bike has been sitting there for two weeks now.
Fri, 15 Sep 2006 17:07:34 +0000
0:7 And counting
0:7 And counting
Fri, 15 Sep 2006 17:07:34 +0000 quote
Piaggio is very much aware of the problem. Insist, politely but firmly, that the GT200 clutch has a very well-known issue that your bike seems to be afflicted with, and ask them to call Eric Larson (at Piaggio) if they're unsure how to proceed. The three pieces of information that they need to tell Eric are "GT200", "Clutch", and "Grind". That should take care of it.
Fri, 15 Sep 2006 19:23:53 +0000
2019 VESPA SPRINT 150
Fri, 15 Sep 2006 19:23:53 +0000 quote
Step 1. Jess' advice is probably good.
Step 2. Call a couple of other service depts and see if you can find someone more customer service oriented. I don't know where your bike is, but I've heard horror stories about some socal dealers. Another shop may say " Oh, the dreaded gt200 grind, we know what to do, can you bring it in Tuesday?"
Step/Option 3. Get a written copy of the repair order complaining of the problem while under warranty. Drive it till it drops. Make warranty claim.
My preferred course of action would be #2. Not only do I get my Vespa fixed, but I'm in the process of developing a good working relationship with a competent, customer oriented shop.
Fri, 15 Sep 2006 19:26:20 +0000
ET4
ET4
Fri, 15 Sep 2006 19:26:20 +0000 quote
Jess, thank you. I just called the dealer's service department with that information. I will keep my fingers crossed and hope that it works. At this point, I am just hoping that I don't have to cart it around from dealer to dealer, paying for them to "diagnose" the problem each time.
Fri, 15 Sep 2006 19:28:41 +0000
Fri, 15 Sep 2006 19:28:41 +0000 quote
I wouldn't be willing to pay them $.02 for diagnosis work on warranty.
Fri, 15 Sep 2006 19:48:06 +0000
ET4
ET4
Fri, 15 Sep 2006 19:48:06 +0000 quote
How do I get out of paying it?
Fri, 15 Sep 2006 19:54:55 +0000
0:7 And counting
0:7 And counting
Fri, 15 Sep 2006 19:54:55 +0000 quote
They shouldn't be charging to diagnose a warranty issue in the first place.
Fri, 15 Sep 2006 20:03:47 +0000
Fri, 15 Sep 2006 20:03:47 +0000 quote
I'm sorry; Ive GOTS to know where your scoot is?
Assuming that you signed an estimate, and assuming that they can actually demonstrate they have performed diagnostic work of some type, you may have to pay. I would be vocal re my displeasure. I have NEVER been asked to pay for diagnostic work on any vehicle in warranty. Calif may or may not have rules in this regard. You may want to call what was called the bureau of automotive repair regarding this issue. It is the state dept governing auto repair; don't know if they have jurisdiction in this case.
Fri, 15 Sep 2006 20:17:47 +0000
Moderator Australis
2014 Moto Guzzi V7 Stone, 2014 Vespa 150 Primavera (sold) 2003 Vespa GT200 (sold)
Moderator Australis
Fri, 15 Sep 2006 20:17:47 +0000 quote
Hi Alice
Good luck with your warranty and service.
In the longer term, and supposing Piaggio dont release a clutch drum modification kit, you may want to consider one of the following.
1. Learning to clean out the clutch yourself via the posts on MV (it's not too challenging).
2. The 'other' solution, of which I have become a recent convert. That is riding your GT a bit 'harder'. i.e. giving it some welly off the lights from time to time. Also some fairly hard acceleration up to motorway speed.
A couple of GT owners I know ride their GT's VERY hard and say they have never suffered clutch shudder. As it reoccurs on my GT, I go for a bit of a blast on the M'Way and really fang it off the lights. It brings a smile to my face and the clutch dust build up appears to clear for the time being.
So in short, your clutch is slipping and causing polishing in the drum, as well as accumulating dust. Make it do more work to 'bite' as it provides drive to the CVT.
Good luck
Fri, 15 Sep 2006 20:46:52 +0000
ET4
ET4
Fri, 15 Sep 2006 20:46:52 +0000 quote
I have never been asked to pay for diagnostic work on any vehicle under warranty, either. But this is my first time dealing with Vespa/Piaggio and it appears to be a whole new ballgame. Apparently, they look around to see if they can find the problem, then they contact Piaggio to see it they will cover it under warranty, then Piaggio decides who will pay. I've never heard anything like it. I've had many new vehicles with warranties and have never once had to pay for diagnosing anything while they were under warranty, regardless of whether or not they could "duplicate" the problem.
Fri, 15 Sep 2006 20:51:13 +0000
Piaggio BV 250
Piaggio BV 250
Fri, 15 Sep 2006 20:51:13 +0000 quote
It's extremely simple. Looks like a known issue to piaggio - it's under warranty - if they want to charge you - give them the number of your lawyer. This one sounds like a class-action waiting to happen.....
Sat, 16 Sep 2006 06:49:51 +0000
GT-200L & 1991 p200e
Sat, 16 Sep 2006 06:49:51 +0000 quote
I don't know if this is "THE" shudder. Grinding noise doesn't quite describe it. If we're talking about the periodic "take off" shudder that occurs in the "lowest gear," it's very clear what the problem is. Are you all suggesting there's some Piaggio solution to this on the GT200? ( I understand it isn't happening on the GTS250. THAT's a mystery )
On my GT200, I have completely overcome the problem. There is no mystery: dust collects on the clutch and the belt. It wrecks the coefficient of friction. I assume.
About once a week I remove the chrome-plastic V-E-S-P-A cover on the CVT and blast 90 PSI air into the three holes. It is a touch more effective when I rev the engine a bit. I can do this at night and with a flashlight I can see the grey dust escaping.
A 50-60 MPH jaunt will do it, but not as effectively as compressed air.
I know this works because the shudder goes away for a while. "A while" being between 5 minutes and 5 days of daily commuting. I think if you search the many threads on this, you'll see buried in the speculation that "cleaning out the clutch housing" is the remedy.
( I know everyone doesn't have an air compressor in his shop. Don't know the solution to that one )
Russ
Sat, 16 Sep 2006 10:51:53 +0000
Scooterless at the moment
Sat, 16 Sep 2006 10:51:53 +0000 quote
My LX150 has started making a rear wheel grinding noise in the few minutes
of take off in the mornings on my way to work and on the way home from work.
I'll ask the mechanic about it today when I take the bike in for the first servicing.
BTW...
I'm finally getting those paint peeled body panels replaced today that the
leaking brake fluid ruined from day one of my ownership.
Dave
Sat, 16 Sep 2006 15:31:46 +0000
0:7 And counting
0:7 And counting
Sat, 16 Sep 2006 15:31:46 +0000 quote
The shudder and the grind are related in that both have to do with the clutch slipping off the clutch bell when starting from a dead stop. The dust is certainly a major factor in the shudder, and may lead to the more severe grinding symptom by allowing the clutch pads to polish the inside of the clutch bell, leading to an occasional complete loss of clutch engagement.
Blowing out the dust definitely helps.
As for the GTS, I've detected some very minor shuddering after repeated low-speed stopping and starting (in-town riding). This usually clears up after a good long fast ride. I don't know of any GTSs with the grind symptom, though.
Sat, 16 Sep 2006 15:58:46 +0000
Sat, 16 Sep 2006 15:58:46 +0000 quote
I got a definite "Shudder" today with my LX150 as I left to take the bike to
the shop for the first warranty servicing, It was reluctant to accelerate and it "Shuddered".
How do you blow the dust out of there on an LX150?
Maybe the mechanic knows, I mentioned the "Shudder" when I got there.
Dave
Tue, 19 Sep 2006 20:02:22 +0000
ET4
ET4
Tue, 19 Sep 2006 20:02:22 +0000 quote
Just an update on this GT-Grind-Clutch issue:
Jess' suggestion to have my service department call Eric Larsen at Piaggio regarding my clutch actually worked like a charm! Mr. Larsen gave them the go-ahead to dis-assemble the clutch and they did find a problem there. They are going to replace the clutch bell and shoes under warranty.
I am thrilled with this tip and thrilled with the results. Thank you, Jess! This forum and the people here are awesome!
Cheers,
Alice
Tue, 19 Sep 2006 20:15:41 +0000
2006 Vespa LX150
2006 Vespa LX150
Tue, 19 Sep 2006 20:15:41 +0000 quote
Let me know what the mechanic says. I am taking mine in for its 2000 mile service and it has a bit of a shudder too.
⬆️    About 13w elapsed between posts    ⬇️
Tue, 19 Dec 2006 06:25:42 +0000
GTS300 Super 2015 Blue, GTS300 Super 2018 White
Tue, 19 Dec 2006 06:25:42 +0000 quote
Just an addendum to an old topic. My GT has just had its 12000km service, and has now acquired a new noise - a sort of screech - which doesn't occur at take-off, but above about 60kph.
During the service I had some Malossi clutch springs fitted - the middle range white ones, which are a bit stiffer than the standard springs. The intention of these springs is to allow the engine to gain more revs before the clutch takes, to reduce/eliminate the take-off hesitation.
I guess that if there is a known problem with clutch bells slipping, then these springs could aggravate the problem, and be the cause of my new noise.
Any comments or experiences with these springs?
Mike
Tue, 19 Dec 2006 06:34:00 +0000
GTV250 GTS 300!! MP3 500, Lambretta TV200 S3 77 07 Aprilia Tuono 1000R 64 Vespa Vbb150
Tue, 19 Dec 2006 06:34:00 +0000 quote
Alice,
How many miles did your scooter have?? I have had the shudderign issue, but cleaned out the clutch which resolved that issue.
Jon
Tue, 19 Dec 2006 21:37:13 +0000
ET4
ET4
Tue, 19 Dec 2006 21:37:13 +0000 quote
scooterjon wrote:
Alice,
Jon
It had somewhere around 2k miles. Haven't had a problem since they replaced the clutch parts, but haven't put too many miles on it since then.
Wed, 20 Dec 2006 00:06:55 +0000
Moderator Australis
Moderator Australis
Wed, 20 Dec 2006 00:06:55 +0000 quote
Hi Alice
The latest development on this front was from Gary ' Addicted'.
The $10 solution is an absolute winner and I have just had a 'shudder free' month following his advice.
The answer is a can of 'Brakleen'.
It works brilliantly!!!!!!!!!!!!!!
http://www.modernvespa.com/forum/viewtopic.php?p=88790&highlight=#88790
⬆️    About 1y elapsed between posts    ⬇️
Sun, 13 Jan 2008 00:53:43 +0000
Sun, 13 Jan 2008 00:53:43 +0000 quote
Dear Alice,
Has that problem of yours vanished completely since you've had your bike serviced? Or has it come back? Mine's doing the same thing. Took it in and they said something about a bearing being rough (wasn't talking to the tech though). It's come back though.
The spraying of brake cleaner in the clutch housing may be helpful, but I shouldn't have to do that on a brand-friggin-new vespa. Especially not once a week.
⬆️    About 36w elapsed between posts    ⬇️
Sun, 21 Sep 2008 17:12:07 +0000
Vespa GT 200 '04
Vespa GT 200 '04
Sun, 21 Sep 2008 17:12:07 +0000 quote
Hi Jess,
Don't suppose this Eric Larson you mention deals with European Vespa clutches too? Mine's doing the same so badly after a ride through London that it sounds like an ocean liner in fog off the lights, and won't engage for about two seconds at worst. Full bore starts are the only way to minimise it.
Did find today though that removing the circular plastic transmission cover that says Vespa on it and going for ride safely above 40-50mph reduced the grind to a less inconvenient minor judder back in heavy traffic if that helps anyone. Might use this trick when carrying a passenger as it seems to develop more quickly and more severely two-up.
Cheers!
David
  DoubleGood Design
[ Time: 0.0373s ][ Queries: 4 (0.0147s) ][ Debug on ][ 277 ][ Thing Two ]
