@oneprairiepiston avatar
LX150
LX150
I have a design idea and will keep you posted on effectiveness and post pictures soon. Essentially just adding wider feet to the existing stand.
If there is interest I will make the process repeatable so I can make them for others.
Re: Market Research...What would you pay for wider center st
One thing to consider is how does it affect the lean angle of the scooter? If it affects it more than the current lean angle allows and someone dive bombs a corner and your center stand lifts their rear tire off the ground you just got served - with a lawsuit, even IF your disclaimer stated that your centerstand affected lean angles.
Not that they'd win in court, mind you, but it could cost you tens of thousands to defend yourself.
Just something to keep in mind.
I don't think I would personally want my center stand to be any wider, for exactly the reason Mike just stated: the potential effect on the lean angle might be disastrous.
@drewteague avatar
@drewteague avatar
Lean angle was my first concern as well, but if the extension was angled or curved similarly to the stand's lever it may work. Maybe something in a similar shape to the lever, but on the right side.
Oh definitely it could be made to work. Just didn't want the dude to go out and fabricate something without keeping it in mind...
@bill_g avatar
2008 GTS 250 i.e.
@bill_g avatar
2008 GTS 250 i.e.
How about something removeable??
My commuter station parking lot is under re-construction and I have been forced to park at times on soft ground. A couple of times I have done so with a wish and a prayer and crossed fingers that the scoot would not tip. It has not, but I have thought that some kind of removeable stand widener would be great. No issues while cornering, then deploy it when needed. Or maybe just a piece of plywood that fits in the top case? Haven't tried that yet.
Re: How about something removeable??
Stomp on a beer can and throw it in your top case. Problem solved.
@ianp avatar
Destroyer of Worlds
LML Star 125, Vespa GT200
Destroyer of Worlds
@ianp avatar
Maybe not longer feet (wider left to right, affecting lean angle) but what about wider feet front-to-back (more foot area)? Basically like the crushed-soda-can-under-the-stand trick but permanent.
@orange_s150 avatar
S 150, VNB 150, 101 Allstate, 01 ET2, 2005 PX
@orange_s150 avatar
i kinda like them the way they are now.
@vezpa avatar
@vezpa avatar
The Centerstand on my 300 works just fine already.
@peabody99 avatar
BMW F700GS, 1996 Honda Helix, Giallo GTS (sold), Buddy125
@peabody99 avatar
I think it would be easier to have a sturdy disk of some kind to put under the stand on soft ground. ie the beer can
@benito avatar
@benito avatar
I am perfectly happy with the design of my 300's centre stand and wouldn't want it to be any wider for the same reasons already mentioned about lean angles.
[ Time: 0.0130s ][ Queries: 3 (0.0031s) ][ live ][ 343 ][ ThingOne ]
