I am trying to decide if I am going to install the tall windscreen on my LXV to expand the riding season. I have the tall windscreen on my other bike (GTS) and it really helps when the temps drop and when I ride on the highways. But the moment it gets hot the windscreen comes off. So the question is...how hard is it to install and remove the windscreen on the LXV.
At first look, it looks like you have to remove the headset and maybe even disconnect the speedometer to change the brackets for the taller windscreen , which is more than I want to do. If anyone out there has done it, can you give a gal the heads up on how you did it..
