@photovillage avatar
2007 GTV250, 1974 European Rally 200, Vespa Primavera ET-e
Hey guys,
Does anyone know if the Vespa branded top case will mount directly onto a 2007 GTV with OEM rear rack or does one have to switch out the rear rack too?
I don't have the black plate I see in other forum posts...but perhaps I need to buy that as part of a 'mounting kit?'
Thanks in advance for any advice!!!
bests,
R
Is that black plate a separate 'mounting kit' or part of a different rack?
The Host with the Toast
If its the GTS top case it will fit on your rack. I just got my mounting kit it was $15.00 @ Vespa shop. it has all you need to install your top case. My case was from a GT200 and I needed to drill 2 holes.
thanks!
Thanks so much!!!
Would you happen to remember which Vespa shop you ordered it from?
I'd possibly mail order it if these guys can't get it for me. They said I needed a part number, which of course I didn't have.
I did get the GTV top case, which I believe is the GTS top case painted in portfino green with a leather back rest to match the GTV seat.
thanks again so much!
Rich
Top Box fitting plate
Part # 623699 $13.79 +tax Top Box fitting plate GTS
Vespa of Long Beach, CA
thanks again!
You seriously rock man!!!!
bests,
R
your welcome ride safe.
[ Time: 0.0174s ][ Queries: 4 (0.0059s) ][ live ][ 343 ][ ThingOne ]
