There is a primer bubble (top right corner in the picture below) that is supposed to fill with fuel after you press and release a few times, but it never will. All it does is push air out one hose but not suck gas in when I let go. So I'm not sure whether one of the valves is not working, or even whether the hoses were connected incorrectly.
What the picture below shows are the two disconnected fuel lines:
The longer one is going into the primer bubble and was connected to a hole in the tank. When I press the bubble, it pushes air into this hose, but it doesn't suck in gas when I release the bubble.
The shorter hose was connected to the tank nozzle, partially visible just behind the end of that hose. This hose runs to the carburetor. Inside the tank, there is a little cylindrical housing, ending in this nozzle, and I believe there is a valve inside that housing. When I removed the hose from the nozzle, with gas in the tank, gas ran out of the nozzle for a moment and then stopped, reduced to a trickle of drops.
The third, black, hose runs from the primer to the carburetor. This is the only hose of which I am sure it is connected correctly.
My question is, where should those two green hoses be connected? Which one goes to the tank outlet nozzle, which one goes into the hole (also leading to inside the tank)?
I was trying to switch those two hoses but can't, they are the wrong lengths to get it switched. Those two hoses were replaced when it was in repair.
⚠️ Last edited by windbreaker on UTC; edited 2 times
