Piaggio BV 500 Tourer
Could anyone please expain, in layman's terms, how a CVT operates? Is it belt driven? Thanks
@baudler avatar
Foiled
Red Primavera
Foiled
@baudler avatar
Red Primavera
Sadly, it is complex and many different types.
http://en.wikipedia.org/wiki/Continuously_variable_transmission
@orange_s150 avatar
S 150, VNB 150, 101 Allstate, 01 ET2, 2005 PX
@orange_s150 avatar
it is kinda a belt driven, to a bunch of rollars and somehow connected to the wheel. it is not hard to work on but kinda hard to explain.
@orange_s150 avatar
@orange_s150 avatar
i stole it from the wikki page
Toroidal or roller-based CVT
Toroidal CVTs are made up of discs and rollers that transmit power between the discs. The discs can be pictured as two almost conical parts, point to point, with the sides dished such that the two parts could fill the central hole of a torus. One disc is the input, and the other is the output (they do not quite touch). Power is transferred from one side to the other by rollers. When the roller's axis is perpendicular to the axis of the near-conical parts, it contacts the near-conical parts at same-diameter locations and thus gives a 1:1 gear ratio. The roller can be moved along the axis of the near-conical parts, changing angle as needed to maintain contact. This will cause the roller to contact the near-conical parts at varying and distinct diameters, giving a gear ratio of something other than 1:1. Systems may be partial or full toroidal. Full toroidal systems are the most efficient design while partial toroidals may still require a torque converter, and hence lose efficiency.
Thanks, you really made that clearer to someone who obviously is just starting the mechanical learning curve.
@orange_s150 avatar
@orange_s150 avatar
lol, i tried... it is kinda hard to explain, what am i forgetting. Nerd emoticon
@dannyh avatar
Resident Gentleman
Resident Gentleman
@dannyh avatar
I don't know. I think this explains it better:
http://www.youtube.com/watch?v=hU0QZQRTNr0
Clown emoticon Clown emoticon
@orange_s150 avatar
@orange_s150 avatar
thats just mean Laughing emoticon
@dannyh avatar
Resident Gentleman
Resident Gentleman
@dannyh avatar
Seriously, though, this thread gives a pretty good explanation with drawings:
What is a Continuously varying Transmission?
Also, here's a good link I noticed in that thread that puts it in motion:
http://www.teamcalamari.com/zumasrus/zdox/ztip4.html
@silver_streak avatar
I wrote up a pretty good explanation a few months ago. Now I just have to find it! Razz emoticon
@dannyh avatar
Resident Gentleman
Resident Gentleman
@dannyh avatar
Sorry, I couldn't resist.
@orange_s150 avatar
@orange_s150 avatar
good post +1
@dannyh avatar
Resident Gentleman
Resident Gentleman
@dannyh avatar
Is this the one you're looking for?
What are roller weights? (Post 620981)
@harvey avatar
@harvey avatar
These may help:
http://www.youtube.com/watch?v=2XDqgGFfCso&feature=related
http://www.youtube.com/watch?v=8VYPsrOyIdw
The idea being the transmission changes its gearing to keep the engine at it's optimal RPM as long as possible.
Harvey
@cajun_critter avatar
07 GT 200
07 GT 200
Check out the below link, it explains what a CVT is, and gives a demo of how it works.
http://www.youtube.com/watch?v=4o7MaM6tk9M
@orange_s150 avatar
@orange_s150 avatar
this puts it best as far as video....cool, now i get it as well...
Please don't think I'm jumping on you (well only a bit) - but if you just now 'get it' - how come you were trying to 'helpfully' explain it earlier? If you know an answer, give it, if you don't, zip. Please.
Yep, that's it! Thanks, Danny.
I just found it on my own, and when I came back here, you'd beat me to it!
@orange_s150 avatar
@orange_s150 avatar
i was winking becouse i was half joking, sorry. i did understand but now a little better than i did, all i posted is what i know and some info i found. just putting it out there but if i did not post it would have fallen off the main page and people would not been able to explain it better. but i offer what i can, even if it is a little. I don't try to act like i know it all, and i give credit where credit is due.
@orange_s150 avatar
@orange_s150 avatar
think of it, before i posted there was not a post in about 16 hrs or so, since i posted in the last 40 mins people have posted i think 3 videos and 2 other talks on MV about it, so i think it helps in a way, but like i said in the other posts, i thanked someone for the wikki post, for a great video, and also a great written post.
Understood - I could always see all the 'helpful' posts were well intentioned - and that's good.
Some of them were missing the target by 180 degrees though. So perhaps a leetle more restraint? I don't want in any way to dampen your undoubted enthusiasm, and I bet within a year of doing all your own spannering you'll be very authoritative - just not quite there yet. OK?
Keep up the good work.
@orange_s150 avatar
@orange_s150 avatar
like i said if i don't see an answer on a post and i think i could put a little input, someone will usally help put in all that i have left out. so i kinda try to work it like a team, and sort of i help get the ball rolling and not always have the best answer. But thanks i love these scooters and learning a lot off of MV because of you guys.
No harm in bouncing ideas - just be very sure none are totally duff ideas!
Thanks for keeping chirpy.
@drewteague avatar
@drewteague avatar
Ok, here's a simplified explanation.
On a multi-speed bicycle, (old style, with several gears at the pedals, and several gears at the rear hub) the smaller the gear is at the front, and the larger the gear is in the back, the easier it is to pedal, but the more limited your speed is. As you gain speed, you can shift to a larger gear up front, and a smaller diameter one in the back. This allows you to continuously pedal about the same speed, while the bike increases its forward speed. This is basically what happens in the scooter, but instead of a set of gears lined up in a row, imagine a cone that turns a belt. (this isn't exactly the hardware used in a Vespa, but it helps to picture it this way) as the belt slides from one end of the cone to the other, the "gear" is changing, not in big steps, but smoothly and gradually. As the belt moves towards the wider end of the cone on the front end, the slack that is taken from the belt makes it travel down to the smaller end of the cone in the back. As this happens, the front cone stays the same speed, but the speed of the belt and the rear cone both go up. The thing that causes the belt to travel up the front cone are weights (called rollers in a scoot) that respond with centrifugal force as the front begins spinning.
Here are some quick paint drawings
@dannyh avatar
Resident Gentleman
Resident Gentleman
@dannyh avatar
Nice, Drew.
@davidh avatar
2009 Piaggio BV250 & 2013 BMW C650 GT
@davidh avatar
Wow, thanks for the drawing and the You Tube video (the good one . I think I'm almost getting it!!!
[ Time: 0.0269s ][ Queries: 8 (0.0134s) ][ live ][ 343 ][ ThingOne ]
