I only use Premium grade as it doesn't hold that much anyway so if I'm spending $5 or $7 it doesn't really matter to me at fillup time...just wondering if there is any kind of a performance difference if you use regular unleaded??? Any thoughts???
Posts: 45965 Location: Pleasant Hill, CA |
The rest of the world uses their version of 'regular' and seem to survive just fine. Piaggio do specify 95RON (tranlates to US 91 octane, but 95RON is the 'regular' here) - but things like altitude, added ethanol, all play their part.
I just use the cheapest I can find at a set of pumps, and I suspect across the planet that's what all scooter riders do. No downsides observed so far. |
S 150, VNB 150, 101 Allstate, 01 ET2, 2005 PX
Posts: 1502 Location: CT |
i have mixed mine in my 150cc with 100 octane and 93 octane 50/50 (making 96/97octane) and i do see a boost in its power. It is not a huge difference but enough that i know it is not all in my head. but i have never used 87 Octane in the scoot to compare it to a low octane fuel.
2008 Portofino Green LX150
Posts: 14 Location: Lavallette, NJ |
i get whatever the best fuel that they have is which is usually 91-94 octane. I live in NJ so we have some of the cheapest gas so why not splurge and spend 5 dollars to fill it up instead of 4.25 ^_^
4 LD's in various states of repair, MP3 500, 1961 Lambro Fli 175, 1965 Topper, 07 GTS250, 81 P200, 79 P200
Posts: 558 Location: The Catskills, NY |
I use the highest grade at each pump at each fill up. My GTS has never tasted regular gas. That's what the book says...that's what I do. Call me a tool but I love my GTS and it has treated me well so far....
There is no point (indeed there may be reasons why NOT to) in using a higher octane fuel then specified in an engine not designed for it. It'll only hurt your wallet, not much else.
Stanny wrote: I use premium, which is usually 91 here. I've heard that it is "cleaner" than regular. http://en.wikipedia.org/wiki/Octane_rating |
Posts: 5707 Location: Santa Cruz California |
Local shop recommends 91. Since I'm still under warranty and the manual specifies 91, I'll stick with it for now. The cost differential is pretty small. On my last bike (Vino 125), I checked milage and acceleration and noticed no difference between 87 and 91 octane and finally stepped down to 87. I'll wait till warranty is up before trying 87.
Best Miguel |
Miguel wrote: Local shop recommends 91. Since I'm still under warranty and the manual specifies 91, I'll stick with it for now. The cost differential is pretty small. On my last bike (Vino 125), I checked milage and acceleration and noticed no difference between 87 and 91 octane and finally stepped down to 87. I'll wait till warranty is up before trying 87. Best Miguel It isn't a matter of "running fine" on lower octane. It is a matter of long, reliable engine life. Use the good stuff and sleep well.
Positive
92 octane unoxygenated (no alcohol) with an occasional dose of Lubro Moly Jectron (Naphtha)
Posts: 16295 Location: Toronto, Canada, Fort Lauderdale, Florida |
Use what is recommended by Piaggio which is 91 octane by the R+M/2 rating system used in the USA. Europe uses the RON system which causes their octane requirements to appear higher, but it is only due to the different rating system.
The book says use 90 or 91 octane, I believe. Initially when I bought mine this spring, I forgot that and was putting in 87 and mine started backfiring. Once I was reminded that it was supposed to be at least 91 octane I only put in premium (can't find 91 around here--mid grade in this area seems to be considered 90 octane) so 93 is what I burn and my 250 runs well on that. Like other posters have said - the difference in the extra cost is minimal and not even noticed in the pocketbook.
I use premium (91 octane available here) and look for ethanol-free whenever possible (somewhat hard to find here since we grow a lot of corn in KS).
Quote: I use the highest grade at each pump at each fill up. My GTS has never tasted regular gas. That's what the book says...that's what I do. Call me a tool but I love my GTS and it has treated me well so far.... |
Miguel wrote: Local shop recommends 91. Since I'm still under warranty and the manual specifies 91, I'll stick with it for now. The cost differential is pretty small. On my last bike (Vino 125), I checked milage and acceleration and noticed no difference between 87 and 91 octane and finally stepped down to 87. I'll wait till warranty is up before trying 87. Best Miguel Lower octane would actually give you more performance in an off handed way...87 is more volatile than 91. But it comes at a cost, in that the fuel will ignite from the pressure and heat in the cylinder before the spark plug...well....sparks. So it detonates. It's a horrible thing for an engine to do, which will only result in damage to your motor. Burt valves, pistons, etc. Usually people will put higher octane fuels in older motors to cure the knocking and pinging that comes about from all the carbon build up and the like. But rarely go the other direction. So, if it calls for 87 and you put 91, then it hurts nothing but performance. Going from 91 to 87 is not a wise move. If you do it, listen to your motor on hot days, or when you are putting a good load on it (such as on a hill). If you hear the tell-tale signs of knocking and pinging, back off the throttle. |
I use the middle button at the pump. I guess I'll have to look at the next fill up and see what octane it is.
A fracking cage sadly
Posts: 4000 Location: Seattle |
That explains why aircraft air-cooled piston engines need really high octane gas! I am assuming that the engine is capable to taking any octane, but has been tuned to 91, so I put 91 into it.
jimc wrote: The rest of the world uses their version of 'regular' and seem to survive just fine. Piaggio do specify 95RON (tranlates to US 91 octane, but 95RON is the 'regular' here) - but things like altitude, added ethanol, all play their part. I just use the cheapest I can find at a set of pumps, and I suspect across the planet that's what all scooter riders do. No downsides observed so far. |
voneschenbach wrote: That explains why aircraft air-cooled piston engines need really high octane gas! I am assuming that the engine is capable to taking any octane, but has been tuned to 91, so I put 91 into it. |
Posts: 23335 Location: Harriman, Tennessee, Tn |
while I don't have a GTS I do use 93 and really try to use only name brand, like chevron,shell,bp,exxon,mobil, but never ever will I use fu**ing CITGO
old as dirt wrote: while I don't have a GTS I do use 93 and really try to use only name brand, like chevron,shell,bp,exxon,mobil, but never ever will I use fu**ing CITGO |
NightWing wrote: old as dirt wrote: while I don't have a GTS I do use 93 and really try to use only name brand, like chevron,shell,bp,exxon,mobil, but never ever will I use fu**ing CITGO http://www.citgo.com/AboutCITGO.jsp |
Aprilia Mojito Custom 150, Aprilia SR50
Posts: 218 Location: San Francisco Bay Area |
I use 91 in both my 2 stroke SR50 and my 150 Mojito. Made a real difference in the 50cc performance.
Kent |
Posts: 4213 Location: San Diego |
NightWing wrote: old as dirt wrote: while I don't have a GTS I do use 93 and really try to use only name brand, like chevron,shell,bp,exxon,mobil, but never ever will I use fu**ing CITGO Wayne B |
Drift Unit SC
1 Manual; 1 Auto; none other.
Posts: 1596 Location: SoSanJo CA |
Drift Unit SC
I heard through a couple people that the CA high octane is actually bad for the GTS (like it destroys/deteriorates the engine, or something)
Instead, the mid-grade is the better choice. Don't ask me. I'm no Piaggio tech. I just follow and respect what my mates tell me. |
ThatBloodyStig wrote: I heard through a couple people that the CA high octane is actually bad for the GTS (like it destroys/deteriorates the engine, or something) Instead, the mid-grade is the better choice. Don't ask me. I'm no Piaggio tech. I just follow and respect what my mates tell me. |
Wayne B wrote: NightWing wrote: old as dirt wrote: while I don't have a GTS I do use 93 and really try to use only name brand, like chevron,shell,bp,exxon,mobil, but never ever will I use fu**ing CITGO Wayne B |
Benelli Boy wrote: Wayne B wrote: NightWing wrote: old as dirt wrote: while I don't have a GTS I do use 93 and really try to use only name brand, like chevron,shell,bp,exxon,mobil, but never ever will I use fu**ing CITGO Wayne B ⚠️ Last edited by NightWing on UTC; edited 1 time
Drift Unit SC
Drift Unit SC
NightWing wrote: ThatBloodyStig wrote: I heard through a couple people that the CA high octane is actually bad for the GTS (like it destroys/deteriorates the engine, or something) Instead, the mid-grade is the better choice. Don't ask me. I'm no Piaggio tech. I just follow and respect what my mates tell me. ⚠️ Last edited by ThatBloodyStig on UTC; edited 1 time
2006 GTS 250ie in Silver
Posts: 1814 Location: Bend, OR |
I only use the highest octane, around 91 locally. We do have a gas station that sells premium gas without the ethanol, but you have to show up with a can to fill. Still worth it!
NightWing wrote: ThatBloodyStig wrote: I heard through a couple people that the CA high octane is actually bad for the GTS (like it destroys/deteriorates the engine, or something) Instead, the mid-grade is the better choice. Don't ask me. I'm no Piaggio tech. I just follow and respect what my mates tell me. |
NightWing wrote: Benelli Boy wrote: Wayne B wrote: NightWing wrote: old as dirt wrote: while I don't have a GTS I do use 93 and really try to use only name brand, like chevron,shell,bp,exxon,mobil, but never ever will I use fu**ing CITGO Wayne B |
GTS250, P200E
Posts: 780 Location: Oshawa, Ontario, Canada |
In Canada, high octane gas (RON+MON/2 =91 or higher) has no alcohol and has the highest amount of detergent. I use it for all of my small engines. Someone mentioned that in Germany you cannot buy low octane fuel any more.
Cheers, Bob |
bendcyclist wrote: I only use the highest octane, around 91 locally. We do have a gas station that sells premium gas without the ethanol, but you have to show up with a can to fill. Still worth it! Less oxygen means less chance of pre-ignition, which is what high octane prevents. |
