SS-180 x 1 (dead) SS-180 x1 (3'rd times the charm)SS-90 x 1 GS-160 MK1 x 1 P-200e x1 TV 175 S2
Posts: 237 Location: San Diego, California |
A friend of mine purchased a new LML five port motor for his Sprint vietbodge and wanted me to install it for him with a new wiring harness switches, bulbs, etc. The install went well and he has had this motor for about a year now. He then decided to get more, "power" from it and decided to kit it and purchased a Pinasco 177 kit and a tuned pipe. When he got the cylinder kit, I noticed that the ports were smaller and that there were only two ports. The LML has three ports in the cases. In fact the ports on the LML cylinder were much larger than the Pinasco kit. Did he purchase the wrong kit? Is there a kit that has the larger ports? I have installed kits before and had to match the cases because they were smaller, but I have never had to match the cylinder. The kit by the way is a cast iron cylinder with an aluminum head. It seems that the power gained by more cc's would be offset by the smaller ports of the cylinder. The kit says it is the largest kit of it's kind that bolts directly into a stock VBB motor. Now I know that a stock VBB motor is a two-port motor and that makes sense if you are not comfortable porting cases, but this does not seem right as the LML motor is not two port.
He bought the wrong Pinasco Kit.
He needs this one: http://www.scooterworks.com/Cylinder_Kit_Pinasco_-_VNX_1_P2501C521.cfm not this one: http://www.scooterworks.com/Cylinder_Kit_Pinasco_-_2_Por_P9943C521.cfm |
VLBJS1 wrote: He bought the wrong Pinasco Kit. He needs this one: http://www.scooterworks.com/Cylinder_Kit_Pinasco_-_VNX_1_P2501C521.cfm not this one: http://www.scooterworks.com/Cylinder_Kit_Pinasco_-_2_Por_P9943C521.cfm |
No problem. I have the same kit (177.7), but I haven't installed it yet. Let me know how it goes.
Thanks, J |
VLBJS1 wrote: No problem. I have the same kit (177.7), but I haven't installed it yet. Let me know how it goes. Thanks, J |
ktmdriver wrote: VLBJS1 wrote: No problem. I have the same kit (177.7), but I haven't installed it yet. Let me know how it goes. Thanks, J |
Posts: 6980 Location: Detroit, Michigan |
Kinda funny, as the pinasco 2-port setup has only been made recently available.
It's the 3-port one that's been out for years and years. |
