@slick_89 avatar
1971 Sprint with P200e
@slick_89 avatar
The 4" wire (yellow) with a ring terminal on it, is it for grounding?
I always wondered that too?? It's bolted on by one of the flywheel cover bolts I think. I looked at my motor the other day and it's disconnected.
Re: whats this Coil wire for?
Yes.
I'd better hook that shit back up
@rover_eric avatar
@rover_eric avatar
It's a redundant ground for your CDI.
See, you had HT coils originally made of Bakelite ..which is non-conductive ...so the old bakelite coils had both a GROUND and a HOT (red ) lead coming off of them.
Then you had the PX125 style black HT coils ... which had that big metal mount that bolted to your engine case, and only 1 ( hot - red ) lead coming off the top. The black was unnecessary because the HT coil itself grounded to the engine case.
Now, the Ducati CDI you've got is encased in black or blue plastic. The White wire ( i believe ) is a ground wire from the stator ... but in order to ground the whole CDI assembly, you use that little yellow wire with the ring tab.
They still work if you don't...but i think it's a beneficial thing to use ( until the yellow wire inevitably falls off ).
The yellow wire with the ring connector uses one of the flywheel cover bolts for mounting correct? You are right...it just falls off somehow.
@rover_eric avatar
@rover_eric avatar
Yeah..it's just a redundant ground to the engine case - uses a flywheel shroud bolt to attach.
And it always snaps off where it meets the plastic of the CDI because there's no strain relief and eventually the vibrations crack it off.
@slick_89 avatar
@slick_89 avatar
thanks all.
BTW this is why I'm fitting a new coil
I was getting a weak and inconsistant spark
Looks like a blue box that caught on fire
Yeah get a new one
[ Time: 0.0094s ][ Queries: 3 (0.0016s) ][ live ][ 341 ][ ThingOne ]
