LX 150
LX 150
This morning my LX150 wouldn't start. i have had it for a couple of weeks. I purchased it used and it had 600kms when I bought it. I have since put another 200 kms on it. From the beginning it always required a bit of throttle to get it going and usually took one or two attempts to get it started. However, today it wouldn't start at all. I didn't have a long time to try and get it going but I did make 5-6 attempts. I stopped because I didn't want to wear down the battery.
I don't think that it's an ignition/battery issue (just a hunch) because when I press the starter it sounds fairly strong.
Since I bought it I have had 2 fill-ups. I may have given it too much gas when I first filled it up. The second time I gassed up I was careful not to overfill and I also added some seafoam as the bike had been inactive for a while. Should I remove the evap hose to see if this will get it started? If so, how do I access the carburetor?
Thanks for any help!
@michael_h avatar
2006 LX150 "Amadora"
@michael_h avatar
Re: LX 150-Starting Issue
If you were giving the throttle a small twist each time, you may have flooded it. On these cooler days, you can use the carb warmer to help out. Turn the engine switch and key on and let the scooter sit for a short period of time (about 1 minute) before you try to start the scooter. Don't let it sit too long because your headlight will also be on (with the carb heater) and will run down the battery.
You may also want to throw the battery on a tender to ensure that it is fully charged..
Also consider doing an idle jet swap at some point. I found that when I switched idle jets, these types of starting problems disappeared.
Replacing LX150 Idle Jet
@silver_streak avatar
Carburetor access couldn't be easier... just lift out the "pet carrier" (the underseat bucket). The carb is right on top of the engine in plain sight.
I don't know what year your LX is but they have a battery that doesn't last more than a few years. I'd look into replacing the battery at some point. Once you start to have problems it's downhill from there Good luck.
@autovoluculum avatar
2009 LX150, 1965 Motovespa 150, 1983 Bajaj 150
Starting Issues: Rain Perhaps?
I have personally noticed and after perusing the forum a bit, realized that the LX 150 has some problems starting within 2 hours of rainfall. I have experienced this after riding in some rain and also immediately after pulling it out of a dry garage. I think that the air is too humid immediately surrounding the engine, so the gasoline doesn't combust. Sigh emoticon
Maybe this helps?
@michael_h avatar
@michael_h avatar
Re: Starting Issues: Rain Perhaps?
Maybe this helps?
Based upon my subjective impression, I haven't noticed this. Perhaps members who live in areas that get more frequent rainfall can comment in.
Maybe this helps?
I haven't noticed this problem either. My LX ALWAYS starts (in cold weather I may have to press the starter button a couple of times due to the infamous "sticky Bendix" problem).
A vehicle that has problems starting in high humidity would be pretty useless.
^ My point exactly. It is really annoying. If I let it run for a few minutes after riding in the rain, it seems like the engine starts better next time. I'm planning on getting a NGK iridium spark plug, but to the original poster, I wonder if it could just be the spark plug? My engine turns and reeks of gasoline, it just never catches during those conditions. Do you experience the same thing?
No, but I'd suspect you have an evap canister problem, not a spark plug problem. But maybe a quick look at the plug and a test to see if you have spark under damp conditions would be worthwhile.
LX 150
LX 150
When I got back from work I was able to start my scooter, it started right away. I went to do some errands and after my first stop I had a hard time starting - took several attempts. So this seems to be an intermittent problem. This weekend I'll do the following:
- Check Spark Plug
- Disconnect Evap hose
- Clean air filter
Is there anything else I should do myself before I go to a mechanic (if my own maintenance doesn't solve the problem?
Thanks again!
PS: I'm not very knowledgeable about scooter repairs but should be able to figure out these 3 items
@trafficjammer avatar
- Check Spark Plug
- Clean air filter
Thanks again!
I have no problems at all starting mine. Aside from the above, you might want to also check your gas filter and try some Sea Foam in your gas tank. Perhaps you got some stale gas, dirty gas or gas with a little water in it? http://www.webbikeworld.com/sea-foam/
@fly_boy avatar
PIAGGIO FLY 150
@fly_boy avatar
PIAGGIO FLY 150
Heres some stuff that may help.
I cleaned the jets in my carb on my 2008 Fly 150 last weekend and took some pictures.
I have been told the engine is the same as an LX.
This can be done with just a few tools.
I have really never worked on cars or motorcycles before.
It took me a few hours but that was due to stripped screws from last dealer service and driving around finding metric screws.
I also took all the covers off to see stripped screws better.
Don't let carb cleaner touch any plastic or rubber! (melts them)
Hope this helps.
Also here is a link to some manuals for LX.
http://manuals.wotmeworry.org.uk/Vespa/LX150/
NUTS THE PICTURES CAME OUT BACKWARDS.
Go from bottom to top. (my first pictute post. Can ya tell?)
The mail jet removed. Use small 6 sided wrench. look down end to see if clear. put on safety glasses and spray with carb cleaner. using a flathead screwdriver about the same saize as idle jet slot. remove and clean it same way. lots of little holes spray
The main jet is on the left, idle jet in the center. (idle jet clogged bad starting dies at stops. main jet clogged engine dies when you give it a twist)
After removing 4 screws, remove bottom of carb. part of the throttle comes with it. be carefull of the floats.(2 black squares on sides of jets.
Rotate carb and drain fuel.put a few towels to catch. about 2 table spoons. note hose and 4 screws on bottom.
Loosen the clamps holding the big hoses on. pry with screwdriver and twist to remove. these are what really hold carb in place, it is not bolted down. Note slots in hoses for replacement.
Auto-choke removed.
Auto-choke removed.
You may need or want to remove auto-choke. 2 screws. catch the black gasket before it drops. there is 1 screw holding the top on you may be able to jet take it off to remove upper part and wires.
Different view of carb showing black cover for auto-choke removed.
Top view of fly with access panel removed. I think LX has better access.
@masala avatar
@masala avatar
946
Well done! Very brave... Now that all's said and done, it wasn't so bad, no? (Save for the stripped screws, which must be the bane of my existence.)
@menhir avatar
@menhir avatar
- Check Spark Plug
- Clean air filter
Thanks again!
Check to make sure that the spark plug boot has a strong connection to the wire. I've know it to loosen to the point where it looks and feels like it's on there snugly, but it wasn't, causing intermittent starting problems (and the problems became worse, I thought, when it was wet). You're going to be in there to check the plug anyway. It screws on and off. So just unscrew it, sometimes you'll see some greenish corrosion, and screw it back on tightly. Good luck.
@scott_nelli avatar
ET4 2003, GTS Super 2013
@scott_nelli avatar
fly_boy, thanks for the photos and instructions. Now the question, is this very similar to removing the carb. and cleaning the jets on an ET4 150? Somebody knows. If so, I'd sure like to save this for future reference.
@benito avatar
@benito avatar
The engine if yours if Leader engine is going to be the same, so it should apply to your ET4.
@scott_nelli avatar
@scott_nelli avatar
Thanks, Benny, but how do you tell if it is a leader? ET4 150 (2003).
@dominick54 avatar
09 MP3 500cc Reddevil, 2011 LX150 IE (Wifes) 2019 MP3 500cc Sport Nightrider (Mine)
@dominick54 avatar
Starting problems
I have a 09 Vespa 150cc I did have some problems starting it, because I had the kick stand up and both wheels where on the ground and I had a hard time keep it running, but when I had both wheels off the ground it starts just fine no problem at all.
@benito avatar
@benito avatar
Sorry for the very very late response. Your ET4 has the LEADER engine as the pre-LEADER engine was phased out in 1999-2000.
@benito avatar
@benito avatar
Re: Starting problems
I wonder if your spark plug harness connection is solidly connected. It might be a bit loose.
[ Time: 0.0257s ][ Queries: 4 (0.0182s) ][ live ][ 343 ][ ThingOne ]
