wrecks wrote:
Can anyone recommend a good Portable Jump Starter? I know at least one of the cars needs 900amps of cranking power.
I live in a sky rise with no access to an electrical outlet. Both my car batteries at times would be dead. Since I got my scoot, I've been neglecting both cars. I try to take them out once in awhile, but if I do not drive them after a week, they will not start.
having the scooters around is definitely a (car) battery killer. I've seriously killed three car batteries out of neglect.
I now have dongles on all my vehicles to facilitate quick hookups to battery tenders.
Imo, if you want to do as you propose, it's still going to be a bear of a "system" to keep up with. My first impulse is to avoid it if at all possible. And by that I mean I would make a serious effort to find a 120v outlet *somewhere* near your car. *any* 120v outlet. It might not be "yours" but if it's the apartment's, perhaps you could "borrow" it once or twice a month.
2nd point: you're
not not not interested in a jump starter. If you've let your battery get down so far as to need a jump start, you're going to kill your battery after only a dozen or so cycles of this, which means about one season of use. What you *really* want to consider is a portable *
trickle charger* so that it never gets so low that you need a jump start. lead acid batteries (even the deep discharge batteries) were never intended for applications where their charge gets down so low. Even deep discharge batteries are best kept above their 60% level as much as possible. Check out www.batteryuniversity.com for background info on lead acid batteries. The difference between an abused battery (a few dozen cycles before failure) and a well-maintained battery (upwards of several thousand cycles) is *huge*.
Ok, so if you're going to do this...imo, what you're really interested in is powering up a battery tender from a portable power source instead of the conventional 120v power source. There's a few ways to go about this. Is the car ourdoors? If so, I'd go solar. It's pricey, but it's sure to work, and the most efficient. cost wise...huge upfront cost, but if you consider that you won't actually be replacing dead batteries quite so often it might seem more reasonable.
If the car isn't outdoors, you are forced to consider more idiotic setups.
There's the idea that you could buy a sacrificial deep draw battery that you charge the others up with. This has some advantages, but larger drawbacks. It is, imo, the 2nd worst option save for the jump starting idea). On the upside, it's a relatively simple concept to implement. You hook up a charged battery to charge a depleted one. The charge levels even out, and voila. But it's downsides are imo large. It doesn't do a good job of charging, because charging a 12v battery actually takes a higher voltage gain on the charging end to push the charge across to the depleted battery. You'll never actually get the depleted battery up to a full charge in this manner. The sacrificial battery will not give all its charge to the depleted battery...they'll just
equalize. You'll have to manually guess whether it's given as much juice is it's got, and in the end...it kills a battery to keep a battery, which, imo, is inane.
No, the optimal solution here if no sunlight is involved is to run a portable power source that has a built in inverter so it can produce 120v power so you can plug in trickle charger into the portable power source and do a legitimate trickle charge. This way, you get several benefits. First, the power reserve in the portable power source is now fully on tap, so it can deplete completely (rather than just reaching equilibrium). Not a good thing for the longevity of the power source, but it's what you need it to do to fully top up the depleted battery. 2nd, you get the benefit of legitimate charging logic from the battery tender, preventing overcharge. You probably have the urge to keep things small when it comes to the choice of which power supply, and my recommendation to you is that that urge is dead wrong. You need to go large, because it's an extremely inefficient and taxing job you're asking the power supply to handle. You're taking 12v power and inverting it to 120v power (an inefficient transformation), and then powering an AC adapter converting that BACK to a 12V charge (again, inefficiently)! Why bother, one would ask? Well, in the process, you buy yourself the charging logic in the battery tender's circuitry. To overcome all this inefficiency, and still have enough capacity in the power supply to 1) give enough juice to depleted battery, 2) power the AC adapter, and 3) not kill itself in the process, you need a BIG portable power supply. And I havent' done the math on it, but I hazard the guess that you really would be most successful w/ the biggest you can get...like...right now I see Duracell has one called the Duracell Powerpack 600...something along those lines.
Like I said, though, my very 1st impulse is to avoid this at if at aaaaall possible. It's alot of hoops to jump through for a rather preventable situation. Running a car for 20 minutes every two weeks or so (at speed...not just at idle), is a decent alternative, or 100ft of outdoor extension cord & a trickle charger every two or three weeks...
