WaspLover wrote:
SimonL wrote:
Thanks all. The case I was planning on using weighs 6kg before I even put anything in it, so maybe I should rethink my strategy
I probably wouldn't put expensive glass at the back of a scooter as well... all that vibration can't be good for precision-aligned optics. A backpack (on your back) might work better.
Yes, that was my other worry, although the Peli cases are fairly well padded as the gear sits in foam. A friend of mine does carry his gear, but he carries it in the footwell. Not so easy on a Vespa due to the raised central 'bit'. I guess the helmet storage will also vibrate a fair amount, so carrying it on my back is the best option (if only it didn't weigh so much though...)
