I am wondering if someone has come up with a U shaped piece of steel that can be welded onto the right side of the center stand? A piece that would not hit the exhaust but would stick out like the left side for safety when down. I always park my GTS with the extended portion on the lower side so my GTS doesn't fall over. Anna's GTS fell over bec when she put it on the center stand the wind knocked it over on it's right side, and no she did not have a windshield.
Sure
When I posted this as a question, I didn't know where to place it, at first it was in the Project Section and that was the incorrect forum. Thank you jess for moving it to the correct forum.
Do you think bikes fall over from bad centerstand? I would think that we always rush and may not get bike on the stand all the way, but draw a picture of what you want, I can have welders at work fab it for you on your stand.
I'm avoiding the whole GTS centerstand issue by getting a sidestand for the GTS 250 that I ordered. It seems to be an inexpensive and effective solution. I've had a sidestand on my Stella for three years now, and i've never had a problem with instability.
![]() Vespa GTS 300 Super & Vespa P125X
Posts: 4134 Location: St. Petersburg Florida |
PeterC wrote: I'm avoiding the whole GTS centerstand issue by getting a sidestand for the GTS 250 that I ordered. It seems to be an inexpensive and effective solution. I've had a sidestand on my Stella for three years now, and i've never had a problem with instability. |
Center stand mod
Here is a rough idea of what it could look like Jesse. The reason I had the large U shape was to not knock into the muffler. It could be welded 1 inch higher then the ground so when it starts to sink into the soft soil the out stretched pcs would stop it from sinking into the soft ground.
⚠️ Last edited by erich51 on UTC; edited 1 time
Has your scooter fell over?, It could be an easy weld job but I'm not sure its worth doing. I find the centerstand to be very strong. if a scooter finds itself on its side its 1 of 2 things IMO, operator error or some jack ass knocking it over for fun, like a cow tip. but if you like get me a center stand and I'll have it done for you.
My scoot fell over one time at band camp....No I mean Sleep Away Camp. Soft ground and center stand do not mix. Bummer, now I have a dented side.
![]() Red 2009 GTS, 2008 Majesty, 2007 People S 200
Posts: 288 Location: Redmond, WA |
Re: Center stand mod
erich51 wrote: Here is a rough idea of what it could look like Jesse. ---Edit: erich51 edited the picture to remove the "U" forward of the foot---- Is the intention to make it harder to push forward, have a larger right foot, and/or a wider stance? ⚠️ Last edited by abobotek on UTC; edited 1 time
Baudler wrote: My scoot fell over one time at band camp....No I mean Sleep Away Camp. Soft ground and center stand do not mix. Bummer, now I have a dented side. ![]() http://www.bestrestproducts.com/c-117-puck-up.aspx Somthing like this is a better Idea. IMO Even better $ .54 at hardware store It's a cover for an electrical box ![]() ⚠️ Last edited by 175mws on UTC; edited 1 time
I've seen something similar done to a Buddy, so I'm sure it could be done to a Vespa by someone with the right tools and skills. The Buddy with the modified stand was for a gentleman who had problems with his right foot, and so could not properly put the bike on the stand the way it was. It was basically modified to have another foot-prop bracket on the left side, so he could use his left foot to put the stand down. Seemed to work just fine, and probably did offer a tad bit more stability. Might need to be a bit stronger for a GTS, though.
Harley-Davidson dealers sell an approx. 8" black plastic puck for a couple of bucks. It's about the only modestly-priced item in the whole store!
the centerstand on my LX is distinctly less stable than the one on my vino, and the one on my motorcycle. It's narrower. So, yes, it's more vulnerable to sideways knocks. The tip on the rigt side is ridiculously pointy, so it's quite happy sinking into soft asphalt. At home I use a foot-long piece of scrap metal under the centerstand. Never thought of welding it on, but if you do, it'd better be some pretty substantial welds, bcs that's a fracture just waiting to happen w/ all the stress it would need to endure.
Whatever you choose to weld on to increase the footprint may be in the way when the stand is up.
175mws wrote: Baudler wrote: My scoot fell over one time at band camp....No I mean Sleep Away Camp. Soft ground and center stand do not mix. Bummer, now I have a dented side. ![]() http://www.bestrestproducts.com/c-117-puck-up.aspx Somthing like this is a better Idea. IMO Even better $ .54 at hardware store It's a cover for an electrical box |
to tell the truth I avoid rock,grass,dirt, or anything that looks soft when it comes to parking My Harley, the scooter I've been lucky I guess it has not fallen over.
abobotek wrote: erich51 wrote: Here is a rough idea of what it could look like Jesse. Is the intention to make it harder to push forward, have a larger right foot, and/or a wider stance? The drawing was just the rough idea of what I wish to accomplish. |
Looking at what you want to achieve may I suggest making the feet of the stand a bit lager by welding on a half circle disk to the bottom of the stand adding more surface area to the center stand. It would be better looking and not take away form the good looks of the GTS.
You can start by cutting different size washers in half to see what would fit then we can weld them on clean it up rust proof and paint black to match stand. If you can get a used center stand even better maybe trade yours to Mossimo after we mod yours |
175mws wrote: Looking at what you want to achieve may I suggest making the feet of the stand a bit lager by welding on a half circle disk to the bottom of the stand adding more surface area to the center stand. It would be better looking and not take away form the good looks of the GTS. You can start by cutting different size washers in half to see what would fit then we can weld them on clean it up rust proof and paint black to match stand. If you can get a used center stand even better maybe trade yours to Mossimo after we mod yours |
'05 Vespa Granturismo
Posts: 1610 Location: Rancho Cordova, California |
Something like this any good ?
http://www.powersport.co.uk/07stockdetail.php?partno=OF103&catno=03&department=Accessories&groupid=0&show=17&group=1 We had similar pads for our folding camper's four corner steadies, although it was never going to turn over in the way we're envisaging a scooter could. They were there to maintain fore and aft and widthways levels by stopping the legs sinking into soft earth. From the pic I can't quite see how they fix but it may be something which could be used whenever conditions warranted it, rather than be permanently mounted (and may be sticking out/fouling bodyparts). UK supplier but I'm sure something similar would be available in the US. Regards Mike |
![]() UTC
Posts: 8758 Location: Annapolis, MD, USA |
![]() 2007 Vespa LX 190, 2011 LXV150ie
60yoMod wrote: Something like this any good ? http://www.powersport.co.uk/07stockdetail.php?partno=OF103&catno=03&department=Accessories&groupid=0&show=17&group=1 We had similar pads for our folding camper's four corner steadies, although it was never going to turn over in the way we're envisaging a scooter could. They were there to maintain fore and aft and widthways levels by stopping the legs sinking into soft earth. From the pic I can't quite see how they fix but it may be something which could be used whenever conditions warranted it, rather than be permanently mounted (and may be sticking out/fouling bodyparts). UK supplier but I'm sure something similar would be available in the US. Regards Mike Whatever is used for parking on the center stand on soft surfaces, you need to make sure the material is tough enough to handle the "point loading" of the stand so that it doesn't punch through. The point loading of a center stand is typically higher than for a side stand and may be several hundred pounds per square inch. |
![]() Reprehensible Misinformant
Posts: 7576 Location: Winchester, California |
widened stance for centerstand
I understand what you are trying to accomplish, and I've seen some people slip a length of pipe, or Rebar steel into the loops that make up the "feet" of the center-stand, after it's down and parked on softer ground....temporary-use if you will.
Of course the length of material has to be wider than the the feet of the centerstand to be effective, and you have to schlep it around with you (shouldn't be a problem!) when not using it, but its pretty effective at making a wider base for parking when you need it and only when you need it. |
"Of course the length of material has to be wider than the the feet of the centerstand to be effective, and you have to schlep it around with you (shouldn't be a problem!) when not using it, but its pretty effective at making a wider base for parking when you need it and only when you need it."
This is why I wondered if a couple of extra (wider) feet might achieve the same result, but just live in the pet carrier when not needed. They probably wouldn't help too much though for the "wind blowing it over" scenario. That's when the length of pipe would score. |
d
60yoMod wrote: "Of course the length of material has to be wider than the the feet of the centerstand to be effective, and you have to schlep it around with you (shouldn't be a problem!) when not using it, but its pretty effective at making a wider base for parking when you need it and only when you need it." This is why I wondered if a couple of extra (wider) feet might achieve the same result, but just live in the pet carrier when not needed. They probably wouldn't help too much though for the "wind blowing it over" scenario. That's when the length of pipe would score. |
Re: Has anyone made an extended U piece for the centerstand?
erich51 wrote: I am wondering if someone has come up with a U shaped piece of steel that can be welded onto the right side of the center stand? A piece that would not hit the exhaust but would stick out like the left side for safety when down. I always park my GTS with the extended portion on the lower side so my GTS doesn't fall over. Anna's GTS fell over bec when she put it on the center stand the wind knocked it over on it's right side, and no she did not have a windshield. |
