Hi all,
Have a new LX125, and many vespas in the past. Have set the clock/date, but the clock never changes time after I've set it. Is there some procedure for 'starting' the clock.
@558 avatar
Kawasaki ER5
@558 avatar
Kawasaki ER5
I have only sucessfully set mine once - i dont know how though. General consensus over the clock is normally that it is a poor design and innacurate so i wouldn't worry too much about it. Mine is now 66 mins fast...
@60yomod avatar
2009 LXV125
@60yomod avatar
2009 LXV125
So I shouldn't be too disappointed the LXV doesn't come with a clock
@chas avatar
ET2
@chas avatar
ET2
I realize this isn't your prob, but when the battery ran out on the ET, I discovered it was more trouble than it was worth to replace the battery; getting to the battery is a long, tedious journey into the inner workings. Best advice I received? Wear a watch.
@harvey avatar
@harvey avatar
Thanks to a post here, I learned that the problem with the GTS clock is (often) the rubber water seal presses down on the clock set button. If you pull up on the rubber bit the clock will work as God and Piaggio intended.
@tb avatar
@tb avatar
Re: Vespa LX125 - clock not working
Camtudor wrote:
Hi all,
I believe you may have to push the bottom button (the one you used to select mode) one more time the "set" the clock. Look and see if the ":" is blinking between the hour and minute hand.
Hope this works!
BTW...I'll be posting a step by step on the replacment of the clock battery as my PTO / Winter Project...it's a somewhat of a hassle...but doable...should be posted in about a week.
[ Time: 0.0085s ][ Queries: 3 (0.0015s) ][ live ][ 335 ][ ThingOne ]
