why not buy the hybrid in the first place?
If you are determined to go with a 400cc hybrid then you should consider starting from the 125cc hybrid and do a motor swap. I doubt that this is doable though. |
psou wrote: why not buy the hybrid in the first place? ... I doubt that this is doable though. |
BubbaJon wrote: psou wrote: why not buy the hybrid in the first place? ... I doubt that this is doable though. Motor change is not appliable to 125cc Hybrid, the electric motor and drive train is in the same package. Also, I don´t love the idea that when the batteries run out on the 125cc Hybrid, the 125cc engine has to carry the whole weight of the bike. 250kilos. Much. I am considering to attach an electric motor to front wheel(s). How about that? |
It would be better to just go with an all electric motorcycle.
http://www.thunderstruck-ev.com/eboxerkit.htm |
jrlwork wrote: It would be better to just go with an all electric motorcycle. http://www.thunderstruck-ev.com/eboxerkit.htm Weight. Because of the mere number of batteries needed, the weight is going to be relatively high and the weight center point relatively high. Not nice to handle. That is why I came up with the MP3, a trike is much easier to balance. Motor. Because of being a carrying piece of structure in a scooter, the motor is a bit difficult to rip off. Range. Due to batteries limitations the range is not high. I am aiming to range over 300 km. Everyday, alltime use. Top speed 120km/h. And if I can do it with - say - 3 litres per 100km, I am satisfied. At the moment I am using a car for the same purpose, 9 l/100km. Not happy with it. ⚠️ Last edited by JaRRmo on UTC; edited 1 time
i think you better use the new 300cc that will be out in 2010 as a LT
it has a Qausar engine, and the Hybride use that one to, so you can use parts from the Hybride that would be more doable, i don't if, easyparts.nl already can suply the parts, last time i looked it said, will be available soon |
Maksor wrote: i think you better use the new 300cc that will be out in 2010 as a LT it has a Qausar engine, and the Hybride use that one to, so you can use parts from the Hybride that would be more doable, i don't if, easyparts.nl already can suply the parts, last time i looked it said, will be available soon |
JaRRmo wrote: [ Thanks for the tip, but the 300cc version will not be on sale in Finland. And the one I´m going to modify needs to be available here in order to save registration costs. Also, the LT has the widest fork. Room to place motors. Piaggio will stop selling the 250cc LT in Europe next march and it will be replaced by the 300LT and european law don't requere a new registration for piaggio, with only an engine change because its the same frame and its registrated as a Car/ Tricycle / Quad ( last one is for Belgium) i've allready seen a kind of new brochure, with only the 300cc LT and 400LT in it both And motorcycle versions 125cc RL, 125 Hybride, 250cc RL and a 400cc RL nothing yet on the 500cc RL |
![]() UTC
Moderatus Rana
MP3 250 and 2 MP3 500s
Posts: 22671 Location: Nashville, Indiana |
Moderatus Rana
![]() MP3 250 and 2 MP3 500s
Just out of curiosity, why do you want a hybrid? I ask because it seems that a hybrid just has more things to break and I am not sure if there is a payoff that is worth it. I havn't heard one yet.
stickyfrog wrote: Just out of curiosity, why do you want a hybrid? I ask because it seems that a hybrid just has more things to break and I am not sure if there is a payoff that is worth it. I havn't heard one yet. One other point: putting the motor up front gives you an all-wheel drive motorcycle. Of course, you cannot make an MP3 all-wheel drive due to differential turning rates (you'd either have to have a split differential or, more likely when it eventually happens, a separate motor in each wheel controlled by a computer that calculates thrust based on turn angle), so not an immediate argument in favor, but someday that will happen. The Suzuki concept trike we've seen pix of does this. I would purchase a hybrid bike in a heatbeat if it was done right. Unfortunately, the MP3 hybrid is turning out to be more of a marketing gimick than a serious entry. Not to dowse water on JaRRmo's idea, but simply adding an electric motor to a gas vehicle does not make a hybrid. The central advantage of a hybrid is the computer system that continuously and intellegently determines where power is being generated and shifts energy pathways between the two systems. What he is contemplating is a bike that can run on either gas or electricity. You cannot power a vehicle with two different power sources simultaneously without those propulsion systems communicating with one another; otherwise, the stronger one simply winds up powering the weaker one and efficiency is lost, not gained. And since that would be installed after the purchase, I suspect there's no tax or licensing advantage to it, either. EDIT: Maksor states below that owning a hybrid can qualify him for exemption from fuel and other taxes and fees. That's an excellent point, but: I'll bet there is an ECD (European Community Directive) that defines a "hybrid"; motor vehicle directives are outside my knowledge of E.U. regulations, but one might want to find and consult it beforehand. ⚠️ Last edited by rjeffb on UTC; edited 6 times
Well in some European countries you don't have to pay any fee's roadtax, parkingtax, ownershiptax and all the other tax, that they can think of, if its a hybride
i paid BPM its a tax, just for buying the thing its EUR 1065.- on a mp3 400 over the whole price including the BPM you pay 19% vat because its light the roadtax is 8 euro a month my car is 86 a month and the bpm was allmost 7000,- euro parking permit for my streat 150, euro a year per vehicle gasprices 1.45 euro a liter 75% is tax so in the netherland if its a hybride no BPM and no roadtax only the gasprice ⚠️ Last edited by Maksor on UTC; edited 1 time
Maksor wrote: JaRRmo wrote: [ Thanks for the tip, but the 300cc version will not be on sale in Finland. And the one I´m going to modify needs to be available here in order to save registration costs. Also, the LT has the widest fork. Room to place motors. Piaggio will stop selling the 250cc LT in Europe next march and it will be replaced by the 300LT and european law don't requere a new registration for piaggio, with only an engine change because its the same frame and its registrated as a Car/ Tricycle / Quad ( last one is for Belgium) i've allready seen a kind of new brochure, with only the 300cc LT and 400LT in it both And motorcycle versions 125cc RL, 125 Hybride, 250cc RL and a 400cc RL nothing yet on the 500cc RL |
Maksor wrote: Well in some European countries you don't have to pay any fee's roadtax, parkingtax, ownershiptax and all the other tax, that they can think of, if its a hybride ![]() |
stickyfrog wrote: Just out of curiosity, why do you want a hybrid? I ask because it seems that a hybrid just has more things to break and I am not sure if there is a payoff that is worth it. I havn't heard one yet. |
![]() UTC
Moderatus Rana
Moderatus Rana
Hmmm, one of my coworkers bought a prius and had some mechanical problems (not sure exactly what they were) but his biggest complaint was he said sometimes felt like a speed bump on his commute to work. Anyway, I guess there may be some good things that hybrids bring. I am not sold on the hybrid bike idea especially the mp3. The one I saw pics of had almost no storage since batteries fill up the pet carrier. Must add a lot of weight too.
Maybe someday the technology will be at a place where a hybrid would make more sense to me but for now I will stick with the good old infernal combustion engine. At least for bikes. |
if you use a 400, it has a Masterblock, so you have to develope all your own parts.
maybe you can look at a Honda hybride because Honda is the developer of the masterblock and Peugoet uses the masterblock to, but Piaggio and peugeot both use the Quasarblock / engines for there hybride's Peugeot used the 125 with a Turbo and the 300cc with a turbo Piaggio only the 125 with out a turbo |
rjeffb wrote: stickyfrog wrote: Just out of curiosity, why do you want a hybrid? I ask because it seems that a hybrid just has more things to break and I am not sure if there is a payoff that is worth it. I havn't heard one yet. ⚠️ Last edited by JaRRmo on UTC; edited 5 times
Well, I don't drive the Prius It was designed for tree-hugging, not for actual performance improvement. The new generation of vehicles, which the Highlander and the Lexus 400h kicked off, are intended to use the hybrid concept to improve performance considerably at a more modest improvement in saving the planet. Also, the biggest mechanical issue with the Prius has been the electric steering - a problem shared by Saturns, which are definitely not hybrids. The potential for hybrid systems in bikes is astonishing - consider what the Vectrix would have been capable of if they had suceeded with their hybrid - and somebody will, building on the mistakes Vectrix made. All-wheel drive alone would be worth it, because that can be tied into computerized stability control. When it happens, it will probably somebody with deep pockets like Suzuki or Honda. |
rjeffb wrote: >Hmmm, one of my coworkers bought a prius and had some mechanical problems (not sure exactly what they were) but his biggest complaint was he said sometimes felt like a speed bump on his commute to work. Well, I don't drive the Prius It was designed for tree-hugging, not for actual performance improvement. The new generation of vehicles, which the Highlander and the Lexus 400h kicked off, are intended to use the hybrid concept to improve performance considerably at a more modest improvement in saving the planet. Also, the biggest mechanical issue with the Prius has been the electric steering - a problem shared by Saturns, which are definitely not hybrids. The potential for hybrid systems in bikes is astonishing - consider what the Vectrix would have been capable of if they had suceeded with their hybrid - and somebody will, building on the mistakes Vectrix made. All-wheel drive alone would be worth it, because that can be tied into computerized stability control. When it happens, it will probably somebody with deep pockets like Suzuki or Honda. Please people, give me proper ideas and not just comparisons. LT 400 hybrid, electric motors in the front. ⚠️ Last edited by JaRRmo on UTC; edited 1 time
Maksor wrote: if you use a 400, it has a Masterblock, so you have to develope all your own parts. maybe you can look at a Honda hybride because Honda is the developer of the masterblock and Peugoet uses the masterblock to, but Piaggio and peugeot both use the Quasarblock / engines for there hybride's Peugeot used the 125 with a Turbo and the 300cc with a turbo Piaggio only the 125 with out a turbo |
[quote="rjeffb
One other point: putting the motor up front gives you an all-wheel drive motorcycle. Of course, you cannot make an MP3 all-wheel drive due to differential turning rates (you'd either have to have a split differential or, more likely when it eventually happens, a separate motor in each wheel controlled by a computer that calculates thrust based on turn angle), so not an immediate argument in favor, but someday that will happen. The Suzuki concept trike we've seen pix of does this. [/quote] Yes, you can make an all-wheel drive of an MP3. And yes, separate motors in each front wheel. Yes, it is a bit trickier with two motors, but hey - that is why the computer is there. What we need is a sensor to check the angle and programs to do the calculations. Doable. |
how do you want to fit it??
i asumed you wanted it to fit like the mp3 hybride so thats why i came with the idee of the Qausar block then you have it a littlebit easer ordering parts and fit them you can try it, like the new electric Solex with a roll on the tire maybe that will work on the front 3 wheel instead of a 4×4 ![]() it will worj with 2 electric engines light ones but the orginal mp3 hybride use its electric power only at low speads 20mph 30km/h above it runs on the 125cc just like the hybride cars ⚠️ Last edited by Maksor on UTC; edited 1 time
[quote="rjeffb"]
I would purchase a hybrid bike in a heatbeat if it was done right. Unfortunately, the MP3 hybrid is turning out to be more of a marketing gimick than a serious entry. quote] Yep. So let´s make one. |
If you want to use the on board alt for charging the batteries, you can hang that idea up now. You have about 15 amps to work with.
Wayne B |
[quote="Maksor"]how do you want to fit it??
i asumed you wanted it to fit like the mp3 hybride so thats why i came with the idee of the Qausar block then you have it a littlebit easer ordering parts and fit them /quote] Well, sorry mate, but you missed the point. Let´s be satisfied with the engine so far. 400 LT it is. Without any changes to the engine. |
do you know the solex mopeds 2 stroke driven by a roll at the front wheel ?
there is no room below the Buddyseat you need that space for batteries so your only optie will be placing at the front a 400 engine is to wide for fitting a altenator on its side thats why Piaggio and Peugeot use the Quasar engines and then there is even a risk to scrape the eletric parts when cornering ⚠️ Last edited by Maksor on UTC; edited 1 time
Wayne B wrote: If you want to use the on board alt for charging the batteries, you can hang that idea up now. You have about 15 amps to work with. Wayne B ![]() |
Maksor wrote: do you know the solex mopeds 2 stroke driven by a roll at the front wheel ? there is no room below the Buddyseat you need that space for batteries so your only optie will be placing at the front a 400 engine is to wide for fitting a altenator on its side thats why Piaggio and Peogeot use the Quasar engines and then there is even a risk to scrape the eletric parts when cornering |
well i've heard that Solex produced a new electric one so look at those maybe you can use parts of them and how do you want to adjust your motormanagement you 400 has to kick in above a speed how do you want to do that ?????? write your own
and the figures piaggio give 1L = 60km they did that on battery power, only 40km on electric and 20 on the 125cc so after 40 km your 400 will only reach 21/22km on a liter a stock one will do 25 to 28km |
>it will worj with 2 electric engines light ones but the orginal mp3 hybride use its electric power only at low speads 20mph 30km/h above it runs on the 125cc just like the hybride cars.
I am sorry to throw water on people's ideas, but that statement shows that you do not own a hybrid or fully understand how they work. No offense intended, just clarifying the science. ALL hybrid vehicles use their electric motors at ALL speeds; there is no running only on electric below a certain speed and only on gas above that speed. The speed you refer to in reference to a hybrid is the speed below which a hybrid vehicle is capable of running exclusively on electricity and above which the electric motor does not generate sufficient power to overcome friction and resistance without assistance. What you are referring to is a dual-mode vehicle, that runs on either gas or electricity, not a hybrid; and although I cannot state definitively, not having read the E.U. regulations, I suspect you will find that such a vehicle does not qualify for the various hybid incentives because they are not particularly efficient. The whole reason for a hybrid's efficiency is precisely because the two motors work as a team, and it was only due to the advent of high-speed computers that this became possible (look up modified Atkinson cycle engines on Wikipedia, computers not only arbitrate between the two power systems but they also operate the valves of the internal combustion engine so it does not create engine braking when the electric motor is operating). And you cannot simply connect a hybrid motor to any given engine e.g. replacing a 125 with a 400, because unlike a conventional Otto cycle engine with a symmetrical stroke profile, each Atkinson engine has a unique, assymetric compression-fire-valve open-exhaust cycle that is orchestrated by the computer. There is a reason why companies are spending billions in research on this and why people aren't just bolting motors to their cars and motorcycles in order to double their mileage - and qualify for government incentives. |
![]() . . 2008 Blue MP3 400. . di Peluria Orso .... 1993 Kawasaki Vulcan 500 ....... 2013 Honda NC700XD; 2017 Versys X300
Posts: 6256 Location: South Cumberland Plateau in Tennessee |
I thought he was trying to accomplish what Peugeot showed off at a show last year.
http://www.likecool.com/Peugeot_HYmotion3_Compressor_Concept--Motorcycle--Car.html There was a thread on it here: [MP3] Future rival from Peugeot at 2009 EICMA??highlight=peugeot The engine is turbo charged giving more power and the electric motors are on front wheels for all wheel drive and more regenerative braking. Edit. Here is a better link to an article on the 3 wheel hybred. ⚠️ Last edited by Fuzzy on UTC; edited 1 time
>Not to dowse water on JaRRmo's idea, but simply adding an electric motor to a gas vehicle does not make a hybrid. The central advantage of a hybrid is the computer system that continuously and intellegently determines where power is being generated and shifts energy pathways between the two systems. What he is contemplating is a bike that can run on either gas or electricity. You cannot power a vehicle with two different power sources simultaneously without those propulsion systems communicating with one another; otherwise, the stronger one simply winds up powering the weaker one and efficiency is lost, not gained.<
Actually this is an idea to do a complete, fullfunctioning hybrid. So yes, the computer system is very much needed and also the code for it. Also the funding is needed ![]() |
Fuzzy wrote: I thought he was trying to accomplish what Peugeot showed off at a show last year. http://www.likecool.com/Peugeot_HYmotion3_Compressor_Concept--Motorcycle--Car.html There was a thread on it here: [MP3] Future rival from Peugeot at 2009 EICMA??highlight=peugeot The engine is turbo charged giving more power and the electric motors are on front wheels for all wheel drive and more regenerative braking. |
rjeffb wrote: >it will worj with 2 electric engines light ones but the orginal mp3 hybride use its electric power only at low speads 20mph 30km/h above it runs on the 125cc just like the hybride cars. I am sorry to throw water on people's ideas, but that statement shows that you do not own a hybrid or fully understand how they work. No offense intended, just clarifying the science. ALL hybrid vehicles use their electric motors at ALL speeds; there is no running only on electric below a certain speed and only on gas above that speed. The speed you refer to in reference to a hybrid is the speed below which a hybrid vehicle is capable of running exclusively on electricity and above which the electric motor does not generate sufficient power to overcome friction and resistance without assistance. What you are referring to is a dual-mode vehicle, that runs on either gas or electricity, not a hybrid; and although I cannot state definitively, not having read the E.U. regulations, I suspect you will find that such a vehicle does not qualify for the various hybid incentives because they are not particularly efficient. The whole reason for a hybrid's efficiency is precisely because the two motors work as a team, and it was only due to the advent of high-speed computers that this became possible (look up modified Atkinson cycle engines on Wikipedia, computers not only arbitrate between the two power systems but they also operate the valves of the internal combustion engine so it does not create engine braking when the electric motor is operating). And you cannot simply connect a hybrid motor to any given engine e.g. replacing a 125 with a 400, because unlike a conventional Otto cycle engine with a symmetrical stroke profile, each Atkinson engine has a unique, assymetric compression-fire-valve open-exhaust cycle that is orchestrated by the computer. There is a reason why companies are spending billions in research on this and why people aren't just bolting motors to their cars and motorcycles in order to double their mileage - and qualify for government incentives. |
I started a new thread on the "future of the hybrid" discussion point since it is getting OT. "Hybrids and Spin."
