I down loaded the MP3 400 maintenance manual and searched for the procedure to replace the antifreeze in my MP3 400, no where to be found. Could not get any response from my dealer or Piaggio customer service. Evidently Piaggio wants you to get the service at dealership which to me is ridiculous since they about 100 miles from home. The service manual really needs an update. According to my hydrometer i am good to +5 F so I am getting nervous about our +10F Temperature outside. Other than that its a great machine rode BMW motorcycles for years and I dont have to shift anymore, wunderbar. Thanks for your help. Georgio :
![]() . . 2008 Blue MP3 400. . di Peluria Orso .... 1993 Kawasaki Vulcan 500 ....... 2013 Honda NC700XD; 2017 Versys X300
Posts: 6256 Location: South Cumberland Plateau in Tennessee |
Re: 2009 MP3 400 Coolant Replacement
Georgio27 wrote: I down loaded the MP3 400 maintenance manual and searched for the procedure to replace the antifreeze in my MP3 400, no where to be found. Could not get any response from my dealer or Piaggio customer service. Evidently Piaggio wants you to get the service at dealership which to me is ridiculous since they about 100 miles from home. The service manual really needs an update. According to my hydrometer i am good to +5 F so I am getting nervous about our +10F Temperature outside. Other than that its a great machine rode BMW motorcycles for years and I dont have to shift anymore, wunderbar. Thanks for your help. Georgio : |
The way i normally do them at work...
Undo the little access cover to the header tank in the front fairing, and remove the cap... ...now remove the small allen bolts around the water pump housing on the RH side of the engine, now pull it away from the engine and let the coolant drain out into what ever container/pan you have underneath... ... Once its finished, rebolt the waterpump cover with copper slip on the little bolts to stop them siezing up in the future as they aint the best metal in the world. Now refill the system with the proper coolant, dont mix colours if possible. Undo the small access hatch near the passenger footrest on the LH side, look at the cylinder head and youll see on the top the bleed nipple, undo this and allow the system to bleed until a steady stream of water appears... ...once this is happening, tighten it up, retop up the header tank then start the engine and let it idle for a few minutes while keeping a shady eye on the dash, if it gets too hot turn it off, if not let it run for 5mins to make sure the thermostat opens and full circuit circulation occurs... once the time is up, turn it off, and wait another 5mins for it too cool down a little, now reundo the bleed nipple and bleed out any remaining airbubbles. Re top-up the headtank and jobs done, have a coffee and feel good about the days work.
Positive
![]() UTC
'09 Mp3-500 - Gone Now
Posts: 2065 Location: Happy Valley, Oregon |
![]() '09 Mp3-500 - Gone Now
cheekythomas wrote: The way i normally do them at work... ......... Re top-up the headtank and jobs done, have a coffee and feel good about the days work. |
MP3 Coolant Replacement
Thanks Cheeky for the procedure. Piagggio designers are unbelievable they require you to take off the water pump to empty the coolant! Why couldn't they just put a plug in the housing assembly unscrew and voila coolant empties out. Another concern I have will the fluid be draining out of the radiator because of its location which appears to be lower than engine bleed that you drain. Right now I will proceed with your method because its getting near 0F here in New Paltz NY. and I don't want my beloved Carmellina freezing up. Hope to get started tomorrow on coolant removal. Thanks Again, Georgio
![]() UTC
Re: MP3 Coolant Replacement
Georgio27 wrote: Thanks Cheeky for the procedure. Piagggio designers are unbelievable they require you to take off the water pump to empty the coolant! Why couldn't they just put a plug in the housing assembly unscrew and voila coolant empties out. Another concern I have will the fluid be draining out of the radiator because of its location which appears to be lower than engine bleed that you drain. Right now I will proceed with your method because its getting near 0F here in New Paltz NY. and I don't want my beloved Carmellina freezing up. Hope to get started tomorrow on coolant removal. Thanks Again, Georgio Why not use some heat tape, an electric blanket or even a 40 watt incandescent light bulb to keep your scoot a bit warmer overnight? Even with better coolant you can't be too careful. Many years ago we did that during the sub-zero nights in Michigan and never had a freezing issue in the pump house or on vehicles (that I can recall...). Seemed like just the little bit of heat was enough, especially with infra-red from a light bulb. Just check it daily to be sure its functional. |
![]() UTC
'09 Piaggio MP3 400
Posts: 184 Location: Richmond, Indiana |
![]() UTC
Posts: 22949 Location: Harriman, Tennessee, Tn |
hk729 wrote: what is the proper coolant? Recommended products SPECIAL AGIP PERMANENT fluid coolant Monoethylene glycol-based antifreeze fluid, CUNA NC 956-16 03_15 03_16 ere is a list of the manuals for the 400 for your reference http://www.scootermanuals.us/manuals/Piaggio%20MP3/MP3%20400/index.htm |
MP3 400, 2008 build, purchased 2009 ex demo.
Posts: 263 Location: Orange, NSW, Australia |
The last post has prompted a complaint I have about the Instruction Manual.
For all fluid replacements and top-up it only quotes 'Agip', the one brand and no alternatives. My problem is that no one in my part of the word has ever heard of that brand and the book does not give any alternatives. It would be great if some kind person "in the know" could give us a list of equivalent products for say Shell or BP or any of the other well known world-wide brands. And while I am at it, Piagio and many others now issue instruction books in about 500 languages. My Instruction book is over 2 cm thick (over 3/4") and only 1/3rd of it is in a language I can read. What an awful waste of paper and cartage etc. Surely it would not be too hard to print a language specific book for each language market! End of gripes! |
![]() UTC
use a Monoethylene glycol-based antifreeze fluid, CUNA NC 956-16
look at the bottles and you can see what the ingrediants are. manufacture doesn't matter. just a 50/50 mix some even comes premixed at 50/50. most auto parts stores should have the right mono-glycol. |
johndunoon wrote: The last post has prompted a complaint I have about the Instruction Manual. For all fluid replacements and top-up it only quotes 'Agip', the one brand and no alternatives. My problem is that no one in my part of the word has ever heard of that brand and the book does not give any alternatives. It would be great if some kind person "in the know" could give us a list of equivalent products for say Shell or BP or any of the other well known world-wide brands. And while I am at it, Piagio and many others now issue instruction books in about 500 languages. My Instruction book is over 2 cm thick (over 3/4") and only 1/3rd of it is in a language I can read. What an awful waste of paper and cartage etc. Surely it would not be too hard to print a language specific book for each language market! End of gripes! |
StooterBoy wrote: johndunoon wrote: The last post has prompted a complaint I have about the Instruction Manual. For all fluid replacements and top-up it only quotes 'Agip', the one brand and no alternatives. My problem is that no one in my part of the word has ever heard of that brand and the book does not give any alternatives. It would be great if some kind person "in the know" could give us a list of equivalent products for say Shell or BP or any of the other well known world-wide brands. And while I am at it, Piagio and many others now issue instruction books in about 500 languages. My Instruction book is over 2 cm thick (over 3/4") and only 1/3rd of it is in a language I can read. What an awful waste of paper and cartage etc. Surely it would not be too hard to print a language specific book for each language market! End of gripes! |
old as dirt wrote: hk729 wrote: what is the proper coolant? Recommended products SPECIAL AGIP PERMANENT fluid coolant Monoethylene glycol-based antifreeze fluid, CUNA NC 956-16 03_15 03_16 ere is a list of the manuals for the 400 for your reference http://www.scootermanuals.us/manuals/Piaggio%20MP3/MP3%20400/index.htm <-----------250 but I was more interested in a brand that others use |
![]() UTC
hk729 wrote: old as dirt wrote: hk729 wrote: what is the proper coolant? Recommended products SPECIAL AGIP PERMANENT fluid coolant Monoethylene glycol-based antifreeze fluid, CUNA NC 956-16 03_15 03_16 ere is a list of the manuals for the 400 for your reference http://www.scootermanuals.us/manuals/Piaggio%20MP3/MP3%20400/index.htm <-----------250 but I was more interested in a brand that others use |
