Where can I buy a key with Imobilizer aside from the dealer? Beacuse I am biding on a vespa scooter with out key. Thank you.
You had better read this article. Buying a scooter without any keys is going to be expensive.
ALL: Programming New Keys |
![]() UTC
Posts: 22933 Location: Harriman, Tennessee, Tn |
Re: Where to buy key for 2008 GTS250?
neil8cruz wrote: Where can I buy a key with Imobilizer aside from the dealer? Beacuse I am biding on a vespa scooter with out key. Thank you. |
![]() UTC
'07 GTS-250ie - sold and gone
Posts: 2023 Location: the Queen City of the West, aka Porkopolis |
![]() '07 GTS-250ie - sold and gone
This post will also be good read: FAQ: Do I Need The Red Key?
Send a PM to Jimh. Jim is a professional locksmith, and a straight-up, eager and able-to-help guy. His website is http://www.allmotorcyclekeys.com/ But yes, it sounds like you will need a new ECU (which means a new throttle body), key switch, and keys; which will not be cheap. |
Cincinnati John wrote: This post will also be good read: FAQ: Do I Need The Red Key? Send a PM to Jimh. Jim is a professional locksmith, and a straight-up, eager and able-to-help guy. But yes, it sounds like you will need a new ECU (which means a new throttle body), key switch, and keys; which will not be cheap. Think you need to get your info straight. An ECU (Electronic Control Unit) and a Throttle Body (the housing the injector mounts to) have no relation except the ECU tells the injector when to inject the fuel. Wayne B
Negative
![]() UTC
The ECU and throttle body are integrated into the same housing. Part number 843017. Parts manual page 46: GTS250 Parts Manual.
Slam not appreciated.
Positive
+1 on what John said. The ECU and throttle body are an integrated unit. Same same.
Wayne B wrote: Think you need to get your info straight.
Positive
To the OP: Buying a modern Vespa without keys is possibly the worst mistake imaginable. The immobilizer is very effective, and as others have stated on this thread, a number of expensive pieces will have to be replaced in order to get it functioning. If it were extraordinarily cheap and you wanted a project, and had a good idea of what you were getting into, I could see it. If you're not well versed in the ignition system of modern Vespas, though, steer well clear.
![]() UTC
Posts: 4332 Location: Utah Valley |
RIP
![]() 29,000 miles on my atlantic pastel green 2007 GTS 250
neil8cruz wrote: I am biding on a vespa scooter with out key. Thank you. a vespa without any key could have been stolen. Bidding on stolen merchandise may end with a headache. |
neil8cruz wrote: Where can I buy a key with Imobilizer aside from the dealer? Beacuse I am biding on a vespa scooter with out key. Thank you. As others have posted, it's probably not worth the trouble. The theft system is very complicated and expensive. |
jess wrote: +1 on what John said. The ECU and throttle body are an integrated unit. Same same. Wayne B wrote: Think you need to get your info straight. All true statements here. SDG |
Guess I have to stay on the MP3 side. Have never heard of anything like that. Why the hell do they integrate them?????
Were they trying to make it as expensive as possible if you loose your keys?? I read on here a LOT and have never seen a post that the ECU and Throttle body were the same thing so EXCUUUUSE ME!! Been working on my motocycles for 35 years. Wayne B |
![]() UTC
A lot of sensors in that housing: throttle position, air temp, pressure, mass flow, humidity too IIRC. It's a busy box. Not sure about the rationale, but I suppose they do it to minimize external harnessing and connectors.
![]() Kymco P250 Now, P200E in the 80's
Posts: 3908 Location: Antelope, CA, USA |
To the OP, if I understand it correctly, loosing your keys (or buying a scoot without keys) has about a $2,000 price tag in getting all the needed items replaced.
Is this a good estimate SDG or John? |
![]() UTC
That sounds about right, including labor. I've never priced the parts, but I wouldn't be surprised at something like $800, just for the ECU/throttle body.
just take the bad feedback from ebay or tell them the seller did not post all the facts on the item
RIP
neil8cruz wrote: Where can I buy a key with Imobilizer aside from the dealer? Beacuse I am biding on a vespa scooter with out key. Thank you. Don't do it. Please the amount of emails i get is silly, and i Can't help. Don't buy a modern vespa without keys. Oh, welcome to MV we are here to help mate. Cheers |
TechGuy9707 wrote: To the OP, if I understand it correctly, loosing your keys (or buying a scoot without keys) has about a $2,000 price tag in getting all the needed items replaced. Is this a good estimate SDG or John? $600-700 kills it. Best, SDG |
SDG wrote: TechGuy9707 wrote: To the OP, if I understand it correctly, loosing your keys (or buying a scoot without keys) has about a $2,000 price tag in getting all the needed items replaced. Is this a good estimate SDG or John? $600-700 kills it. Best, SDG |
