175mws wrote:
try JB weld and fine sand paper, it may work
I agree about the sandpaper but I wouldn't use JB weld on a rim. If they are that messed up that you are thinking about JB weld then you really need to replace the rim.
You need to dismount the tire to fix the rim . Use a couple different grits of sandpaper gradually working finer and finer to smooth out the scratches.
After you are done have a dealer install the tires back on the rims using a good rim sealant. Believe it or not Windex works best. You can submerge the rim in a tub of water to check for leaks.
⚠️ Last edited by VEZPA on UTC; edited 1 time
