Anyone have any experience with the Malossi roller weight 16grams? Original want to buy dr.pulley's but scootertrap no longer selling those and only have the Malossi's in stock.
Malossi weights work effectively the same as stock rollers do, they just use a different material to reduce wear. Stock weights use a plastic composite which can wear pretty quickly and get large flat spots on them. Malossi uses a nylon composite to reduce this wear. The weights don't necessarily need to be changed the same time as the belt... just check for weight and wear.
+1 (for Dr Pulley sliders and not malossi roller weights). I got mine in two weeks. Overseas communication can be challenging but Paul really comes through.
So the opinion is get Dr.pulley from Paul over the Malossi? Thanks for the quick reply, happy new year guys.
I can't comment on the actual use of either just yet since I have yet to install mine, but there's plenty already said on the Dr Pulley sliders in other threads here, easily searched out - and it seems to me that the sliders have very good feedback.
All Content Copyright 2005-2025 by Modern Vespa. All Rights Reserved.
