@noth avatar
Burgman 650 (May, 2012) MP3 500 (11/2009 - 5.2012)
@noth avatar
I did a search first, but found nothing on this.
The turn signals on the 500 are on little arms or stalks that are somewhat flexible.. I came out this morning and found that my cover was tight (due to rain) and the left front one had popped out of it's mounting. I looks like a little ridge to get it back in, but try as I might, it won't pop back in. I finally found some black electical tape here at work and taped it in place. I will ask the dealer to fix it, I suppose, but awfully fragile. anyone else have this sort of Problem? Whats the secret to getting it to pop back into th emounting? I pushed fairly hard, but really don't want to break it.. It still works, and with the tape, you can hardly even tell there is a problem..
Live & learn.. Nerd emoticon
Thanks..
Honda Elite 80 , Mp3 "Nyx" 500
The secret is a screw driver...
I've had these pop off, as they are designed to do instead of breaking. you unscrew it, slide it into the slots and then screw it back in. Takes 2 minutes tops when you have the screw driver ready.
@bubbajon avatar
RIP: MP3 500 - Brutto Moto
@bubbajon avatar
Yup - meant to pop off - actually a darned nice system.
Unscrew the screw holding teh clear part on. You'll notice there's a sort of slide that slips over teh stem. Slip it back on - reattach lens and you're ready to rock.
@noth avatar
@noth avatar
Ahh Ha ! Thanks to you & Bubba John.. 8) I knew there had to be a secret to it..
@noth avatar
@noth avatar
Shifty & Bubba..
Thanks very much.. I fixed the left front turn signal on my 500 when I got home tonight from work.. I had my doubts, but gave it a try and then figured it out when I took the light apart and saw the fork shape on the end of the reflector.. The only problem I had was getting the screw in as I wasn't sure about the direction and the screwdriver that came with the tool kit was not the best fir for the Phillips head.. I had a better one in my tool kit in the house and then it was easy !! Clap emoticon
@sushiman007 avatar
She's an I-talian $$-burning machine
@sushiman007 avatar
Now, if you could just fix that profile pic.
@noth avatar
@noth avatar
I'll work on it.. The file size is awfully small.. I gotta futz with a new one a bit..
@sushiman007 avatar
@sushiman007 avatar
@volosong avatar
2010 GTS 300, 2008 MP3 500
@volosong avatar
In the course of the past two days, I "broke" both front turn signals while maneuvering in tight spaces. Those things sure stick out. Was all ready to purchase some new ones, but will print out this thread and take a closer look tonight with a screwdriver.
@noth avatar
@noth avatar
designed to pop off.. and easy to pop back on..
@bubbajon avatar
@bubbajon avatar
Don't be fooled - you *can* break them. I had one of mine pop out the embedded nut. Not a chance in hell of getting it back in normally. I had to slit the plastic, weasel the nut back in and the epoxy it. It's held but now that I know you can break them I'm extra careful.
@soeley avatar
Fuoco 500ie SOLD
@soeley avatar
Fuoco 500ie SOLD
I managed to do the same thing, but got the nut back in place after standing the rubber in a cup of hot water for a few minutes.
@georgiagirl avatar
Piaggio MP3 500
@georgiagirl avatar
Piaggio MP3 500
Bumped mine off twice pulling up to the same gas pump as my hubby. We'll be too close and when his bike leans over on the kickstand his Bandit's new luggage is just the right height to pop my blinker off. Pops right back on. Don't remember how we did it, but it must not have been hard because I did it while he was paying for the gas. They are easy to knock off, my MP3 didn't even jiggle and the blinker popped off clean
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
if the topend pops off simply unscrew the lens and you see the reflector (silver part is loose) form the holder you can slide it back on it
When it's off the Nut use washing up liquid or soap or tyregrease and it pops back on again
or you can orde these they are 1.5" or 2" long and the light is brighter then the orginial ones
they are also on my trailer
@volosong avatar
@volosong avatar
Update
Left side was as described. Removed lens and just slid the chromed reflector "U" tab back onto the black housing. Re-attach lens and all set. Right side had the hollow bolt pop out of the housing. After dis-assembly, ran under hot water for about 20 seconds, but still hard as a rock. Will try again letting it sit in hot, hot water and use some liquid dish washing soap to try to make slippery enough to slip back in. (How'd they get those things in there in the first place?)
Thanks for the advice and relating experiences. Saved me a bunch of cash ... (I hope, do be determined if I can pop the bolt back in on the right side).
@soeley avatar
Fuoco 500ie SOLD
@soeley avatar
Fuoco 500ie SOLD
Make it a cup of boiling water
@mplkn avatar
2009 MP3 400ie
@mplkn avatar
2009 MP3 400ie
This was actually a factor in my deciding on the 400.
I was examining both at the dealer, side by side. Was thinking about the 500: bigger engine, lots of luggage attachment points, etc, when I noticed that the 500 had one of its front turn indicators loosly dangling, hanging down by the wire. Looking at it, I wondered if it would just pop back in - tried the fit - couldn't determine whether if would pop in or not... Then I wondered what the dealer would think if I was there leaning over the bike on the showroom floor trying to pop the ferschluginer turn signal back in! Wha? emoticon
Took another look at the 400. Faired-in turn signals. Hmmm. Lots of enclosed luggage space. Hmmm. A little less expensive. Hmmm.
So I took the easy way out. Not a slam on the 500 - far from it - but the turn signal was a little something that made my decision easier that day...
Best wishes to all --
Michael
mplkn
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
Welll the fenders with the turn signals in them, on a 400 will come off as easly as the turn signals on a Fuoco / 500
i think this is a solution
@volosong avatar
@volosong avatar
Maksor wrote:
...i think this is a solution
But who carries these in the states? The TNT web site is worthless. After what seems like "hours" and several tries ... I can't find those signals, what the model number is, who makes them, etc. Do you have a link you can post?
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
look at my location i'm not in the States www.easyparts.nl sells them
http://www.easyparts.nl/showarticles/0-4-295-692-190/Knipperlichtsets-compleet.html
@volosong avatar
@volosong avatar
Yes, I saw your location in your first post about he lights. I was just hoping that you could supply a manufacture or part number and if you knew an importer. Your link helps. THank you. Alas, they do not ship to the states. Looks like this is the model:
Knipperlichtset Arrold Homol TNT (in black)
OAD, I was looking at those this afternoon. Maybe a second choice (if I can't fix the OEM one I have). The Knipperlichtset is a lot more attractive to me than the DMP lights. Then again, difficult to really see if one cannot hold them.
@rjeffb avatar
Bracketmeister
Bracketmeister Emeritus (retired)
Bracketmeister
@rjeffb avatar
Not to rain on anyone's parade, and I realize that the chances of getting caught are slim to nil, but: OAD the signals you linked to are for dirt bikes (the link even says so), for on-road motorcycles capable of greater than 30mph, NHTSA requires turns signals to meet SAE 588 and FMVSS 108, which in turn require turn signals to have an area of at least 12.5 square centimeters. Those tiny signals Maksor posted, while perhaps brighter and logically safer, don't meet the federal requirement, and I would be skeptical of any U.S. signal that is labeled as for off-road vehicles or doesn't say meets DOT or NHTSA requirements.
think about this for a sec.
Dirt bike signals for what turning at the next tree?
turn signals are made for street use. Application what ever you want to install them on. They bikes don't know any different. If they are brighter than stock "DOT" approved signals who's going to tell you you can't use them. There ain't a cop who will check the stampings on them. they just want you to have them and in working order. bet they can't even state the distance requirement for visability if you were to ask them face to face.
@rjeffb avatar
Bracketmeister
Bracketmeister
@rjeffb avatar
I think I prefaced my citation appropriately. My concern in any event would not be law enforcement but state vehicle inspection personnel, whose job specializes in that area. As I clearly stated, low to nil risk.
@stooterboy avatar
MP3 500
@stooterboy avatar
MP3 500
Safety inspection station won't catch them unless they are really anal.
And most dirt bike lights are just more flexible and do meet DOT Reg.
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
the ones i bought aren't for a dirtbike but for SS bikes
maybe when i am able to use my righthand im going to install them friday or saterday and make a pic in the sorry state its in now all leftside covers are off now ready to be painted
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
some installed them for me
@bubbajon avatar
@bubbajon avatar
I like 'em - nice and tucked in. It's surprising how easy it is to bump the stock lights.
@rjeffb avatar
Bracketmeister
Bracketmeister
@rjeffb avatar
Being the resident regulatory expert, I of course would never recommend anybody put anything on their scooters that do not fully comply with federal standards...
...but those lights look fantastic!
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
i think the laws in europe are how do you call that? more a pain in the a@#$ and these are TUF aproofed
@volosong avatar
@volosong avatar
Final follow-up
That's the trick. "Boiled" it for just a minute or two ... fished out with a "L" shaped screwdriver ... shook most of the water off ... and popped the bolt right in. Very easy as the rubber was just pliable enough. Thanks for the tip. Both turn signals are back on and working fine now.
Still like those lights Maksor showed. Too bad we can't get them here.
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
easyparts will ship over the world if you explain in a mail that you realy want them shipping will be 6 or 7 euro's so together it wil be 25 euro's
@ljclark avatar
None
@ljclark avatar
None
Also: http://www.kandstech.com/pimages/25-9900D.html#
...which someone here installed on their 500.
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
ordered these today for a friend's GSX-R
@gopam avatar
2016 BMW R1200RT & 2007 GT200 & 2020 Vespa GTS SuperSport 300 HPE,2024 Honda ADV 160
@gopam avatar
Thanks to all of you & this thread. I knocked my right turn signal off today slowly maneuvering out of a tight parking lot by a pole. Followed these instructions with a screw driver and back in business baby. good as new
@noth avatar
@noth avatar
I did it that one time and have never done it again.. But now it's an easy fix..
[ Time: 0.0359s ][ Queries: 5 (0.0199s) ][ live ][ 313 ][ ThingOne ]
