I fitted my HiT Dr Pulley clutch this morning and thought I'd let people know how I got on.
My bike is a 2009 MP3 400.
Prior to fitting I had bought a 55mm socket for the clutch nut, but that was about it. I also made a 'home made' clutch compression tool. This consisted of a 1inch thick piece of MDF, about 2 foot by 1 foot. I cut a hole out of the middle large enough for my 55mm socket, and glued some foam from a camping roll matt underneath, with a similar hole cut out.
All in all it was surprisingly easy, given how anxious I was about the clutch flying across the yard when I took the nut off!
Remove airfilter cover.
Remove plastic transmission cover.
Remove metal transmission cover.
Remove outer variator half using buzetti tool.
Remove clutch assembly and belt.
I then put the clutch flat on the ground on a camping roll mat and put my 'compression tool' piece of wood on top. I then knelt on the wooden platform. I then removed the clutch nut using an impact driver. Quick and simple. I then anxiously released the pressure on the spring, but no problems at all under my weight.
Fitting the new clutch was also straightforward. Line it up. On with my wooden plank. Kneeling on it easilly compressed the torque spring and I put the nut back on by hand. Then, still kneeling on the plank, I did the nut up to torque using a torqe wrench.
Following this I put the transmission back together.
I've only been for a ride around the block, but the new clutch seems excellent, a real improvement on the OEM. Smooth, lag completely gone (for this experiment I also took my fuzzy washer out), and quick. Pick up from low rpm is also excellent. From standstill bike will now rev to 5k plus (was 4500 max before) from standing and pickup is really prompt. The only thing I did notice was some slight clutch 'chatter' as low rpm, but maybe this will settle with riding (or not).
My plan is to ride with this setup (I have 17gm Dr Pulley weights in at the moment) for a while, before deciding whether to experiment with stronger clutch springs for peppier take off.
Thanks for all your help and advice. No piccy's I'm afraid, as I had limited time and no one to assist.
