@atlgts avatar
GTS 250 i.e. "Silver Bullet"
@atlgts avatar
So I was on my way home from work this afternoon, and I hit a small bump in the road,a nd all of a sudden, my GTS sounded like a Harley. The engine light went on immediately, so my first thought was that one of the bolts that attaches the exhaust header pipe to the cylinder head snapped off.
Drove the final 1 mile home gingerly, and immediately inspected. Fortunately not the bolt, but the actual header pipe snapped off No real rust, I think it just had a bas spot in teh steel, and weakened over time, and eventually just gave out.
I then tried to remove the exhaust, so that I could get the header pipe off, but whoever attached the Leo Vince pipe used about 200lb/in of torque to tighten the bolts. I got two of them loose, and then stripped out the bottom one - not good. So out comes the hacksaw. I cut off the head of the cap screw, and once the mounting plate was off, I removed the O2 sensor (I know it has a proper name, but I can't remember it now), and the exhaust came free. Got the header pipe nuts off by looking through the battery compartment, and the whole exhaust assmebly is now off.
This does explain a few things i noticed while riding the last few weeks, though:
1. Acceleration was bad
2. Fuel consumption went up (i.e. got worse)
3. No/little mid-range power the last few weeks
Phoned my Vespa delaser to see if they had a replacement part in stock - no luck. It's going to take 10 days to get a new one (internet shopping, here I come). The workshop manager there said he had never even hear of this happening.
Here is a pic of the exhaust header pipe that broke. I'll do a reassembly article of the put-back, if anyone is interested.
How deep was the pothole that you hit? I wonder if you also may have bent a wheel?
@atlgts avatar
@atlgts avatar
No pothole, just a small bump in the road. Hardly even noticed it.
The Host with the Toast
Snapshot05 has one just like it.
Your dealer (deaf bloke obviously) may have never heard of it, but it happenened to me on my X9 250 in 2005 (and to many others). And yes, roads that promote resonant vibration are often the primary trigger.
"never heard of it" What a tit.
@atlgts avatar
@atlgts avatar
That was my initial reaction... And the fact that he's only able to get the spare part in in 10 days is why I'm going to be shopping online for this specific part...
@abobotek avatar
Red 2009 GTS, 2008 Majesty, 2007 People S 200
@abobotek avatar
Sorry to hear about your misfortune.
Is there any reason why the pipe couldn't or shouldn't be welded back together? That might be better than waiting 10 days.
Many on MV (thanks!) have suggested that copper grease be used on the muffler and a few other nuts and bolts. IMHO this should be part of the 600 mile service.
FFS, copper grease has nothing to do with this. It's a stress fracture in the SS downpipe because the exhaust clamp over the graphite collar was over-tightened by some monkey. These things work really, really well and last for ages if they are *understood* - or even ackmowledged as existing!
So some old geezer (could have been me...) who's done nothing but Mustangs in the past now works on these pernickety beasts? Not going to work...
@atlgts avatar
@atlgts avatar
Welding is not really an option for me (no access to a welder).
Seems like Motorsport Scooters is the best option at this point... $146 before shipping. Damn, I was hoping this wouldn't be quite this expensive...
Such is life, I guess...
@harvey avatar
@harvey avatar
There's been a few threads about the Leo Vince cracking header pipes
F-ing Leo Vince exhaust - broke my second header
Best suggestion is to be really careful lining up the muffler/pipe to avoid stress fractures.
The stock system has it's weak point too, so it's a case of choosing your poison.
@fluffy avatar
Beverly 350 "Mavis"
@fluffy avatar
Beverly 350 "Mavis"
Or, you can replace the lot with a PM Tuning PM68- its a complete system including the header (if you can get it stateside, that is)
Then again, you will sound like a Harley with a PM pipe!
Honda Foresight 250
Honda Foresight 250
A PM pipe could also result in a significant lightening of your wallet from what I've seen, but I suppose none of these damned exhausts are cheap really.
@bill_dog avatar
eeeee bip
BMW R1100RT The Problem Child Kymco Downtown 300 - I'm not the Uber
eeeee bip
@bill_dog avatar
Grey/Gray
Bill says keep it standard.
Is it me or is that engine burning a bit lean ?
@atlgts avatar
@atlgts avatar
It probably was running a bit lean from when the pipe cracked until it finally broke off. Under normal circumstances the EFI O2 sensor should take care of that, though.
@karmann avatar
2007 Avio Grey GTV
@karmann avatar
2007 Avio Grey GTV
atlgts - the reason Scooter Superstore never heard of it happening is because it almost always happens in combination with LV pipes and there aren't many people running them here in Atlanta. Read the thread linked earlier or the "Official LV Pipe" thread and you will see numerous incidents of this happening (including my own). All it took was once for me and I put the stock pipe back on (after having it ceramic coated).
If you decide to keep the LV on your GTS, try having the head pipe welded up at a muffler shop. It will be a lot cheaper than a new one.
@atlgts avatar
@atlgts avatar
Thanks Karmann - any suggestions on a decent muffler shop that can do the welding?
0:7 And counting
0:7 And counting
To me, this looks like a classic off-angle downpipe break to me, caused by imperfect alignment of the LV components. There are three main components in this setup: the can, the intermediate pipe, and the stock down pipe. The intermediate pipe and the stock down pipe, in particular, have to have the correct rotation between them so as to go perfectly straight into the can. Any slight angle will cause pressure on the components, and after repeated cycles of heating and cooling, the stock down pipe typically breaks first.
@atlgts avatar
@atlgts avatar
Let me ask a stupid question (because I can't find the installation instructions anywhere):
I know there is a graphite collar that fits in the standard exhaust. Is this collar also required for the LV pipe? There isn't (wasn't) one on the current configuration, but a few people have mentioned it, so IDK...
Sorry for the stupid question...
@karmann avatar
2007 Avio Grey GTV
@karmann avatar
2007 Avio Grey GTV
Is it required? Yes. Does the LV use it? No. And that's the problem. The LV is a rigid setup. It doesn't have the graphite collar and slip joint that allows for vibration, or expansion/contraction.
No, but most any shop should be able to handle it. Its especially easy for them since the part is off the vehicle. It should only take a few minutes.
⚠️ Last edited by Karmann on UTC; edited 1 time
That was just me missing your mention of Leo Vince - I had to do lots of horizontal scrolling to read your OP. I had assumed a stock exhaust, sorry.
@atlgts avatar
@atlgts avatar
Ahhh, cool. Thanks Jim. Sorry about the big pic. I'll make them smaller next time...
@atlgts avatar
@atlgts avatar
So I'm wondering if it isn't possible to put a 1/8" thick heat-proof rubber gasket in between the flange and the engine to help dampen the vibrations. Surely that would help... Thoughts?
@karmann avatar
2007 Avio Grey GTV
@karmann avatar
2007 Avio Grey GTV
Probably not. What you need is a slip joint between the head pipe and muffler, not between the head pipe and engine. It needs to allow for movement of the two pieces where they join.
@harvey avatar
@harvey avatar
There was some previous mention of welding in a section of flexible exhaust pipe:
Head pipe broke !!!
@elvispa avatar
GTS 300
@elvispa avatar
GTS 300
Correction...
Actually, I would prefer the mellow roar/rumble sound of a hog to the sound of my PM68. It is not overly loud, it just isn't a good sound--sorta like a chinese scooter with a hole in the muffler.
The PM68 was a little bit more $$ than the others, but I think it was probably worth it.
>>Or, you can replace the lot with a PM Tuning PM68- its a complete system including the header. Then again, you will sound like a Harley with a PM pipe!
@atlgts avatar
@atlgts avatar
This has me thinking now...
What about replacing the middle section of the LV pipe with a piece of flexible exhaust tubing? I mean, there is a joint at the base of the muffler part of the LV Exhaust that simply clamps on, and then there is the dreaded connection with the header pipe. Will this significantly reduce performance, even if you keep the diameter the same? This should solve the probelm, no?
I'm thinking something like this:
http://www.jcwhitney.com/flexible-exhaust-tubing/p2006251.jcwx?TID=8014524FT2&utm_source=Google_Product_Search&utm_medium=CSE&utm_content=product-16251G&zmam=15972153&zmas=18&zmac=129&zmap=16251G
From a support perspective, I think the 3 bolts that attached the hanger bracket to the exhaust should be sufficient to carry the weight of the exhaust, but it might need another support point...
@atlgts avatar
@atlgts avatar
Or what about something like this?
@drewteague avatar
@drewteague avatar
kewl
@karmann avatar
2007 Avio Grey GTV
@karmann avatar
2007 Avio Grey GTV
Worth a shot I guess. You may have a hard time finding the correct diameter though, as most of the stuff like that is sized for automotive exhausts.
@atlgts avatar
@atlgts avatar
I just got the header pipe welded up at the local Midas - $40... Doesn't look too bad, and I'll see how it runs. I've got a new one on order, so this is probably only a temporary fix. I'm not expecting it to last very long, but I thought its worth the $40 and 20 minutes it took to at least try it. I'm still thinking of experimenting with the flexible hose option, if I can find one that fits.
@atlgts avatar
@atlgts avatar
I just reinstalled the header pipe and the Leo Vince. That header pipe is a real bitch to get tightened down properly. Don't even think of attempting it if you don't have a socket with a swivel head...
Took me almost an hour to get the header pipe back on, and only about 5 minutes for the rest.
Can't start the scoot now to see/hear how it runs (it's 1:55 am, and my wife would kill me ). I'll start 'er up first thing tomorrow, and go for a wee test run.
@benito avatar
@benito avatar
Good to hear about the progress you've made.
[ Time: 0.0208s ][ Queries: 5 (0.0063s) ][ live ][ 313 ][ ThingOne ]
