MichaelR wrote:
That is really an excellant video and as you can see it isn't all that difficult. I will add two things: 1) When you are removing the screw underneath the headlight I stongly suggest you hold a magnet against it while unscrewing it. If you drop it, it goes way down inside and you have to take a lot apart to try and get to it or go out and buy a replacement which is a pain. 2) Doing this with your shirt off is optional. Good luck and tell us how it turns out.
That is a great video - thanks Mitch! One more caveat though - don't just muscle the mirrors loose. First, pull up the rubber boots at the base of the mirrors by turning them so that the thick part faces forward, then just slide them up the mirror stems. Next, unscrew the brake reservoir covers and slide them up the mirror stems as well. Then loosen the locking nut at the base of each mirror, and both mirrors should unscrew very easily without any effort.
The pitfall with muscling the mirrors off is that this can damage the threads, because the locking nuts place tension on the threads to keep the mirrors from moving while riding. If you strip the threads on the mirrors, you'll need to buy a new pair, which aren't all that cheap (unless you can find a good set of used ones); if you strip the threads inside the headset, you'll need to buy a whole new brake reservoir for each side that's been stripped, and those are definitely not cheap!
