Vespa T5
Vespa T5
Hi, Any help here would be appreciated,
The spring off the tick over screw in the carb has fell through the port into the crank and seized the engine,, it is half sticking out, but stuck fast....
Any ideas,, apart from a full strip down,, Bearing in mind my scooter knowledge is very limited and only have Mr Haynes to help!!!!
And to happen when the weathers so nice too....
@greasy125 avatar
@greasy125 avatar
full strip.
you could 1/2 ass it and maybe free it up by rotating the flywheel backward but more than likely you'll gonna need to split the cases.
best,
-greasy
@rover_eric avatar
@rover_eric avatar
You're going to want to inspect any damage you may have done to the crank web and it's mating surface ( the rotary pad ) on the engine case.
px200
px200
Hello
Full strip and check the rotary pads for damage.
Grumpy
Vespa T5
Vespa T5
Cheers everyone,strip down it is, thought as much,,,
me and Mr Haynes are gonna be gettin quite upset with eachother this weekend,,,,,,
An T5bitsa,, "how did i manage to do that"
Well, doh rebuild ya carb with 2 little kids hangin on ya,,
Say no more,, I'm wounded,, an it's Run to the Scrum rally jus round the corner from me tomorrow.........
@eurochris avatar
1980 P125X / 1984 P125X
Location: Portland, OR USA / Nürnberg, Bavaria, Germany
@eurochris avatar
Yeah, sorry to hear about that, definately unfortunate!
You are going to need to open up the cases for sure to inspect the damage(hopefully none....). There is a possibility that the rotary pad may have been damaged, as well as the crank web surface.
Your haynes manual, scootermercato.com tutorials, or vespamaintenance.com should be able to help you step-by-step to remove the engine and pull the cases apart.
Please post pictures so we can help in assessing the damage (like I said, if any at all).
Sorry to hear about it! Good luck!
Cheers,
- Chris
[ Time: 0.0085s ][ Queries: 3 (0.0018s) ][ live ][ 313 ][ ThingOne ]
