Rickyh wrote:
I have an early p and the harness has the following colored wires for the stator. 2xyellow, 1xgreen, 1xblack, 1xpurple.
I am putting together a motor and I am going to need a stator soon. Which stator is the easiest to adapt to this harness? The bike has a battery but no electric start.
You are wanting a new stator for the SAME scoot which used the double yellow? The EASIEST thing would be to fix your double-yellow you have, or find another double-yellow for replacement. Otherwise, if you want to use a single-yellow stator (much easier to find) you'll have to alter your harness is my understanding.
1977-79 Ps (serial pre-34627) have stator plates with a 1A or 1B stamped on the back, a mostly unobtainable 4-pole regulator, an unobtainable 4-pole keyswitch, and a speedo in mph only. Off the stator plate you'll have double-yellow wires to the regulator, purple to the headlight, black to ground, and red/white/green to the CDI. The tail- and brakelights will only work when a battery is in the frame.
1980-82 Ps (serial post-34627) have stator plates with a 2A or 2B stamped on the back, a 5-pole regulator, an 8-pole keyswitch, and a speedo in both mph and kph. Off the stator plate you'll have yellow & purple wires to the regulator, red to the battery, black to ground, and red/white/green to the CDI. The tail- and brakelights will work off of the magneto.
Perhaps there's a hack on the BBS about rewiring a single yellow to work on a double-yellow setup... I've seen a number of discussions about the two stators there. But the path of least resistance would be to stay double yellow I think.
