Got my Stebel TM80/1 (Blazer high tone) installed in about fifteen minutes. A couple of minor challenges were encountered, but no showstoppers. I should say that these data pertain to the 2011 LX150ie. Having never seen first-hand the interior fittings of any other year or model Vespa, YMMV...
The stock horn was mounted to a tapped bracket and bolted to the fitting above it, which was also the mounting point for what appeared to be a relay. A 10mm gearwrench did the trick and the stock horn came right out.
The Stebel took a bit of turning and jiggling before I realized that it would only fit in one orientation. That is, with the trumpet facing the left side of the bike.
I bent one of the brackets supplied with the Stebel to mate with the tapped fitting in the bike (the one with the relay mounted on top) and bolted the other end to the threaded stub on the back of the horn. A 13mm wrench was the right fit here. I got the whole assembly into the bike with a minimum of jiggling, attached the two wire leads and test hooted the new horn. Loud!!
I repurposed the 10mm nut that held the stock horn to its bracket to attach the new Stebel/bracket assembly to the tapped fitting on the bike. A bit of masking tape around my index finger to hold the nut in place under the bracket worked fine while ratcheting the gearwrench to snug things up.
Another test hoot to see that all was well, and I got everything buttoned up. No stress at all. I realized too late that pics of the process would have been great. Mea culpa. Next time!
Ken
