i did not know if there are any ticks to installing prima pipes on my s.
the strap broke about a week ago and i had my work make me a new thicker one. it works well but now the motor sounds different. not by a lot but that is does not backfire anymore. (it is not loud anyway but it would make some noise when you back off the throttle) could this be a leak in the seal up where the motor is? visually it looks alright, but idk when it gets up by the motor if something is not fitting right and that is the problem. thanks for your help.
