@taurian avatar
2009 GTS 300 Super
@taurian avatar
2009 GTS 300 Super
Hi Guys - need your help diagnosing the problem with my Pre Leader 1998 ET4. It's not normally the best starter in the world from cold , but today when it did eventually start it was very lumpy and didn't sound right plus a little bit more smoke from the exhaust than normal. I thought I might have flooded it as I have to give the throttle a few twists normally to get it to fire up. Anyway, it cut out after a minute and I thought I'd leave it for a few hours to evap the excess fuel in the carb. I looked in the oil sight glass and I couldn't see the oil level - which is normally exactly where it should be - right between min and max. I undid the oil filler cap and oil started to gush out. The oil also smelled alot of petrol too so I imagine petrol has got into the oil - is that probable?? Anyway, I suppose I'm going to have to drain the oil out and refill, but is there anything else I should be aware of - like is my engine nackered?? Crying or Very sad emoticon
@dougl avatar
El Macho
Vespa GTS 310
El Macho
@dougl avatar
Vespa GTS 310
Sounds like your fuel tap has died. Your engine is probably fine. Your carb is probably getting a constant supply of fuel and flooding the engine. Could also be your float.
@taurian avatar
2009 GTS 300 Super
@taurian avatar
2009 GTS 300 Super
Thanks for your reply dougl. I'll check it out. Presumably I'll have to drain the engine oil as it's probably contaminated with petrol ?
@dougl avatar
El Macho
Vespa GTS 310
El Macho
@dougl avatar
Vespa GTS 310
Yeah I would. But it will evaporate fairly quickly, although the lubricant property of the oil would be significantly reduced.
[ Time: 0.0100s ][ Queries: 3 (0.0030s) ][ live ][ 343 ][ ThingOne ]
