125 delux star
125 delux star
hi just purchased a 125 delux star off ebay.went to liver pool and collected in van.yesterday filled up 2 stroke tank ready to take for mot.got up today and 2 stroke leaked all out not sure where from and how to locate leak as cant lift top off.any ideas
@danifly avatar
09 Triumph Bonnie, 06 Kymco P250, (Retired: 05 Stella , 08 Piaggio Fly150, 02 Yamaha Vino50, 07 Yamaha C3)
@danifly avatar
You should post this in the not so modern section
or go to www.Modernbuddy.com
and the folks at www.stellaspeed.com will have more info.
Good luck!
Dani
@xmanhoe avatar
@xmanhoe avatar
just get a jug and pre mix 2% like the old days lol
@jcwhitney avatar
Lambretta SX, Stella, Honda
@jcwhitney avatar
If you filled above the tank proper up in to the standpipe there is a threaded connection that can leak.
@bagel avatar
@bagel avatar
Sounds to me like it's time to pull the tank and take a look. Hopefully it's just a loose fitting that you can tighten down (oil tank to the fill tube, or at the banjo fitting on the bottom of the tank, or possibly a loose oil sight glass). The worst case scenario would be a cracked oil tank, but a new one shouldn't cost too much & isn't too hard to replace. Good luck!
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
the oil line from the tank to the carb might be split. It could be split where it attaches to the tank, but I found mine was split right where it passed out of the frame to the carb. You couldn't even tell as it was hidden in the grommet. But years of flexing at that point had caused a nice split there.
All easy stuff to check. All you need is a screwdriver and a socket wrench and an hour (at most)
[ Time: 0.0085s ][ Queries: 3 (0.0017s) ][ live ][ 343 ][ ThingOne ]
