@stevieapollo avatar
px150 m166,stella 08
i was wondering if anyone had used a p200 clutch in there 05 px150? i was told that the cosa clutch was no good if you were running performance parts.
I have a 166kit with 24/24 carb.
also is it normal to hear the transmission spinning when the clutch is not engaged? the noise goes away once i pull the clutch in...its not super load but it is noticeable.
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
Re: cosa clutch or p200 clutch in 05 px150
The gears are always in motion in the transmission when the clutch is engaged (clutch lever disengaged/not depressed). When in neutral the gears simply aren't connected to the driveshaft/axle
@t5bitza69 avatar
T5s
@t5bitza69 avatar
T5s
on me head son
i ran a polini in a t5 everything else was standard.... the clutch couldnt handle it and i did the rodeo at the red light take off ... ended up on my back with scoot ontop of me... and that was a heavy fullframe mk1
i always use cosa clutches now for that smooth pull away ... the best thing for kitted lumps i think
@greasy125 avatar
@greasy125 avatar
keep your stock cosa and get uprated springs and carbon plates.
if you're making serious power just band the basket and weld the rivets.
best,
-greasy
px200
px200
Hello
My PX200 is standard and when the clutch is rotating in nuetral it makes a hell of a racket, pull it in and all is quiet and its been that way for thousands of miles.
Grumpy
[ Time: 0.0075s ][ Queries: 3 (0.0017s) ][ live ][ 343 ][ ThingOne ]
