@sterling avatar
et3 & primavera
@sterling avatar
et3 & primavera
I have been lurking for far too long - time to step out of the shadows. I ride around boston on smallframe vespa's. currently I am in the middle of replacing a throttle cable and it is giving me hell If any body wants to maybe give a hand with this one - dinner and beer is one me. what a pain in the ass these things are - but we all know how worth it is. anyway, I love this forum.
@sterling avatar
et3 & primavera
@sterling avatar
et3 & primavera
I meant to say dinner is ON me. 8)
Welcome!
Celtics fan here...my heart sunk last night but whatever.
This will be a huge help for you:
http://smallframes.com/
Check out the tech section and you will be on your scoot riding around in no time.
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
Hey mate, it's rare to see a northeaster like you on the forum! Welcome! Hit me up if you want to go for a ride
nothing at all
nothing at all
i like to remove the speedo as well as the lamp
the throttle cable is pretty skinny so be sure to have the right size
if your keeping the outer then thats cool, lyth the cable and feed thru from the carb end first(so the soldered nipple is at the carb end), turn adjuster all the way in on the carb and slip the nipple on to the throttle arm
the bitter end should be at the headset, you will find it easier to if you clip exses after you slip on the barrel lock
pull the slack,not to hard(helps if a buddy pushes on the idle screw so it is touching the carb body)tighten the barrel lock, if there is to much play in the throttle turn then unscrew adjuster(i have about an 1/8th to a 1/4 play in the throttle
clip exsess from the barrel
good luck
@sterling avatar
et3 & primavera
@sterling avatar
et3 & primavera
The outer is still in - so thats good. the speedo is out. the problem is that the end at the headset is not properly lined up with the slot - not to mention the fact that I dont have the right cable Once I get my hands on the right cable - i will give it another shot. I am replacing the cable because it was stcking. I had cruise control for a while 8)
nothing at all
nothing at all
not unusual for a smallframe
everything has to be just right for a smooth glide
i'm not suggeting this, just that when my cable broke i needed to get the bike back on the road for work
i went to high end bicycle shop with my old cable and the guys matched it with a slightly smaller guage cable with the nipple at one end
what a difference and bullet proof
i am not suggesting that anybody use anything other than a proper cable from their scooter shop
if you have the time just order a full set from max at motorsport, they are the proper lengths and guage-25 bucks for the lot
[ Time: 0.0148s ][ Queries: 3 (0.0063s) ][ live ][ 313 ][ ThingOne ]
