Piaggio mp3 125
Piaggio mp3 125
Just wondering if anyone had any ideas:
Engine maintenance light on
Eventually peters out at idle
Won't start without a bit of throttle
Occasionally backfires when trying to start
Ideas welcome, I was thinking spark plug or timiings?
Many thanks
Tom
@stooterboy avatar
MP3 500
@stooterboy avatar
MP3 500
Get a can of Throttle Body Cleaner and a tooth brush. Pull the air cleaner housing clean the throttle body. Open the butterfly while doing this and get everything really clean. You most likely won't be able to see the dirt, it is a very light coating and throws off the air fuel mixture at idle.
@bravotwofour avatar
'09 Mp3-500 - Gone Now
I know you have mentioned this procedure many times before, and I have not yet felt a need to use it myself. But questions arise in my mind: so if you use a solvent and a brush to loosen the varnish inside the throttle body, where is the dissolved stuff going? Are you trying to wipe it out or just let it sit and hopefully evaporate / burn up? Thanks.
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
Stooterboy
if you needed to clean your throttlebody how dirty was it and how many miles did you do
if its getting real dirty there most be something wrong with your airbox / filter
+/- 27.000 km or 16.900 miles and i never had to clean it and i do drive on dirtroads
Piaggio mp3 125
Piaggio mp3 125
It might be something more problematic (hope not) but I just noticed that the idle speed before it started spluttering and dies was down at 1300. I just adjusted to 1750 and the cut out problem seems to have gone for now. It starts just using the button too!
Doesn't explain the warning light though...
@stooterboy avatar
MP3 500
@stooterboy avatar
MP3 500
Maksor wrote:
Stooterboy
This is very common problem on vehicles with a vapor recovery system like on the MP3. It's caused by the crankcase vapors getting recirculated into the intake.
I had 18,000 miles on it and as soon as I did the throttle body cleaning the problem was gone and it ran like new again.
It doesn't get real dirty, just takes a little build up to throw the air fuel mixture off. It's not anything you can see.
@fuzzy avatar
@fuzzy avatar
Good input from Cheekythomas in this thread with pictures MP3 500 ECU version?
Piaggio teaches this and it helps for stalling issues. Made a big difference on my 400 with 20,000+ miles on it.
[ Time: 0.0113s ][ Queries: 4 (0.0035s) ][ live ][ 313 ][ ThingOne ]
