battery isn't charging.
Battery is good
Replaced rectifer (didnt help)
There is voltage coming from wire from stator (3-5 volts)
Please help
nothing at all
nothing at all
Re: P200E Electrical
Battery is good
Please help
best place to start is scooterhelp.com and find your diagram in the wiring section
make sure yours is like it
there is usually a violet or something coming from the batt and spliced in with the fuse to the battery
if that wire is not connected to the rec in the slot its supposed to be in you wont get a charge
alot of people cross the two violeys/purples on the rec
@sean_s avatar
bunch "o" bikes
@sean_s avatar
bunch "o" bikes
Year of bike?
5 wire, 7 wire or double yellow wire stator?
Is the fuse good?
Zombies?
Battery is good
Please help
There is a black wire comes from the rectifer to the negative terminal of the battery. Red wire, positive has a fuse and does not go to rectifier. My understanding is voltage trickles to the battery through the battery ground from the rectifier.
sean s wrote:
Year of bike?
Is the fuse good?
Zombies?
1979 scooter
5 wire rectifier
yellow runs from stator(internally) to rectifier another runs from stator to regulator whichs gives spark to sparkplug, another runs from stator to the headlight.
All is good except battery isn't charging.
@rover_eric avatar
@rover_eric avatar
I was always under the impression with the double yellow stator that the two coils had tied together but were inversely wired.....such that they fed the rectifier the full wave....with each yellow handling one half of the AC sign wave for full wave rectification.
are you speaking to the 5 pole rectifier? one yellow runs to the CDI unit which fires sparkplug.
I'm beginning to think my positive wire from battery may not wired to stator as per wiring diagram.
full investigation underway next weekend.
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
I don't think you should have a double yellow stator with a 5-pole (not without modification). Could you clarify the colors coming out of the stator?
@skyjumper avatar
2007 Vespa GTS 250/2009 Buddy Various Stellas 1960 VBA
@skyjumper avatar
Battery is good
Please help
Stator voltage should be much higher than 3-5 volts. I would start there.
@sean_s avatar
bunch "o" bikes
@sean_s avatar
bunch "o" bikes
sean s wrote:
Year of bike?
Is the fuse good?
Zombies?
1979 scooter
5 wire rectifier
Hold on....the Regulator/rectifier has nothing to do with the sparkplug.
We need to know the colour of the wires from the stator (under the flywheel)
@rover_eric avatar
@rover_eric avatar
a double yellow stator has the
RED, WHITE and GREEN wires that run to the ducati CDI.
obviously 2 yellows that run to the rectifier...
and i think a purple that runs to the rectifier as well, but is a straight-AC line that's meant to be regulated and then run to the headlight.
this is all from memory, though.
@skyjumper avatar
@skyjumper avatar
A double yellow stator can't be used directly with a 5 pole regulator unless one of the yellow wires is grounded.
However, I would check into the stator voltage. It's much too low.
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
*partial but related thread jack* Have you made progress on hooking up the double yellow up to your Stella?
@rover_eric avatar
@rover_eric avatar
The thing is - if it's a '79 engine, it's likely got a 4-pole rectifier on it. The problem is that people sometimes confuse the 4 and 5 pole ones, thinking the 4 have 5.
So, i'll ask the thread poster to either get a pic of his rectifier and post it, or tell us if there are two poles on it that are marked yellow ...
[ Time: 0.0236s ][ Queries: 4 (0.0126s) ][ live ][ 313 ][ ThingOne ]
