@kdude avatar
@kdude avatar
My 2010 carb'd S150 came with a tag for with 4 numbers on it. Can i order another key using the code from this tag ? It has four digits ?
@stooterboy avatar
MP3 500
@stooterboy avatar
MP3 500
A hand written tag? Most likely an inventory tag from the dealer. Any key codes come on a plastic card and that is just the cut code, not the code for the immobilizer.
@jimh avatar
MV Saint
Haud yer wheesh't if ye cannae be nice
MV Saint
@jimh avatar
Mate, Because your scooter is a non-transponder you would have received a small plastic tag with your digits. What may be missing from your tag is a "W" which is the prefix that Giobert/Zadi uses for the locks our scooters use.
Most other models should come with a code card. If you wish, PM me a picture of your key and i will give you the code you need.
Hope this helps.
Cheers
The smartest thing you can do re. a spare key for your Vespa is to ship you red key to JimH who posted directly above me. He made spares for four Vespa's that we have owned and it's done correctly and at a good price with great service. He has helped hundreds (if not thousands) of people on this forum with his key services.
@kdude avatar
@kdude avatar
Scootboy ... the tag is plastic green and was attached to the org. keys
Jim your right the keys are do not have the immo. like my 300. i would send you the keys but i already misplaced/lost one set and if i send them i'll not be able to ride.
XLR ... i have total confidence with Jim and wouldn't hesitate in a heartbeat...
@dutch avatar
LXV 150 GTV 250
@dutch avatar
LXV 150 GTV 250
Yes Jim is the absolute best on keys and locks !!!
He's done all my keys and locks on my scooters.
@voyageur5 avatar
Vespa GTS 250 ie (2007)
@voyageur5 avatar
Fot Vespa keys
Berthiaume in Montreal = $$$$$
4398, Rue de la Roche, Montreal, QC, H2J 3J1
514-521-0230
Moto LS in Saint-Jean-sur-Richelieu = $
1070, boulevard Du Seminaire Nord, Saint-Jean-Sur-Richelieu, QC, J3A 1S7
450-348-4343
Then go to a locksmith, my favorite is:
Serrurier K G O Locksmith Inc
930, avenue Sainte-Croix, Saint-Laurent, QC, H4L 3Y6
514-744-6211
These guys rekeyed my top case in half a day and also cutted me a coded key that I brang them at a very very good price
@stooterboy avatar
MP3 500
@stooterboy avatar
MP3 500
Or send the key to JimH, who will sell you a key for the best price around, clone it if that is needed and cut it for free. Just let him know you are an MV member when placing your order.
http://www.allmotorcyclekeys.com/products.php?cat=20
@dooglas avatar
GTS 300ABS, Buddy Kick 125
@dooglas avatar
Am I missing something here? You have a working key and the key code for a non-immobilizer scooter. Any competent locksmith with the right blank can make a duplicate key for you in a few moments. (not that I doubt jimh's ability to handle the job well and properly - it is just that this doesn't seem like a problem that would require you to mail off your only working key)
⚠️ Last edited by Dooglas on UTC; edited 1 time
@tb avatar
@tb avatar
1+ I sent my brown key (Master) to JimH and had only my original blue key in possession...got everything done and returned to short order.
kdude make a couple of duplicates...one to ride and one for easy access as your backup and then keep orignal locked away.
@stooterboy avatar
MP3 500
@stooterboy avatar
MP3 500
Not true, most seem to have too wide a cutting bit for the Piaggio keys and it ruins them.
And he needs the key, which JimH has the best price and service hands down.
2004 ET4
2004 ET4
i can't find an address to send the key to from jimh's site-- for some reason i was under the impression the place was moving. is it back up and running?
@tb avatar
@tb avatar
Per Jim's post...PM him (below)
Note: Many of our local Vespa group have used Jim...no problems.
2004 ET4
2004 ET4
Sorry, I meant for cloning my own key, per your last post about only having the blue key,but I'm confusing things.
@dooglas avatar
@dooglas avatar
I'm not sure where you are getting this information but my local Vespa dealer simply takes blanks (standard or blue electronic) down to a local locksmith here in town and gets them cut. He says there is no problem doing this and he must be correct as he had a duplicate blue key made for me which works fine. The whole problem arises when you want to duplicate the red key, or if you have lost the red key, for scooters with immobilizers. Then you need someone with special knowledge and skills. And, yes, the electronic key blanks are expensive but we aren't talking about an electronic key in this case. The keys for the S are a standard double cut key.
[ Time: 0.0082s ][ Queries: 3 (0.0019s) ][ live ][ 343 ][ ThingOne ]
