blackbart wrote:
If that is your wiring diagram, you have a rectifier/regulator with two AC wires in (yellow) and two DC wires out. Your tests seem to show the stator is providing AC, but the regulator is not providing the DC output. It changes the AC to DC and bleeds excess voltage to ground simultaneously.
Another way to test it is to use a lamp such as a brake/tail light fixture with the typical 1157 bulb and first attach one stator yellow wire to the fixture ground and the other yellow to one of the other lamp wires, run the engine, and see if the lamp glows. If it glows, the stator can provide load and should be okay. It may blow the lamp when you rev it up. Oh well, sometimes sacrifices have to be made.
Then unhook the regular wires to the regulator DC terminals, hook up the test fixture and see if it glows while running. If not, faulty rectifier. If it glows, but your voltmeter shows low or no DC when hooked back up, possible short somewhere on + wire.
Another test is to hook a diode bridge rectifier's AC inputs to the yellow wires, and hook the lamp to the + and - and see if the lamp glows and/or blows while running. If so, bad regulator.
Make sure there is no short on the DC out wire before buying a regulator.
Thanks, Blackbart! I ran your bulb test suggestion on the yellow AC wires and got a glowing bulb (didn't want to rev it and blow it up, because i'd near to re-solder wires to another bulb).
I then put the positive wire from the bulb onto the B+ pole and the negative onto the vespa body. No glow. I then put the + wire on the C pole; no glow.
What I can tell is that these tests show that my rectifier is no producing DC power out of either the B+ or the C poles, and is fried. I'm glad to have found the source of the problem, however upset that I bought this Ducati rectifier from Scooterworks about 2 years ago and it is already pooped.
Thank you to all who helped me diagnose the source of the problem; hopefully others will see this thread and gain some knowledge on how to do the same with their vespa.
Side Note: Does anyone have a suggestion for a replacement rectifier? I don't want to shell out ~$150 again for a genuine Ducati...
Best,
-Peter
