hp wrote:
There's a couple ways you can go with this. If you are running without a cowl you can get the cool flip choke from dellorto and flip it manually.
Otherwise, you can modify an old throttle cable to work with the choke knob. Just cut it so only the throttle nipple remains, and thread it back through the existing choke outer cable. Once it pokes out the choke tube, you can cut it short and fold it through the choke lever and push it back into the body. May take a little bit of experimentation to get the correct length, but I think those chokes have an adjuster too, right? So you can probably do the final adjustment with that.
If you don't have a throttle cable to work with, any stranded cable will work you just need to crimp something on the end that will activate the choke plunger.
Thanks for the reply! I'm hoping to have the cowl in place, so the flip-lever isn't going to be suitable... The stranded cable that's there now comes from the carb, but has no outer sheath... I think I understand what you're saying, but maybe it'll be clearer to me after I take out the gas tank and have a look at what's inside the body behind the hole where the choke knob goes... Seems like I'm going to need some sort of outer sheath over the choke cable, regardless of what else I do... and I bet there's supposed to be a grommet of some sort where the choke cable enters the body of the scooter, yes?
Thanks again,
Joe
