jimc wrote:
May I inject a cautionary word here.
The 'notch' is eff-all to do with lack of grease - grease isn't actually important for these bearings - there should be enough to keep crap out, but that's it. The actual surfaces that meet have no grease between them - they are static surfaces in the main, and there probably isn't a molecule of grease left between them, even after the treatment above. It's metal to metal. If there's room for grease - they're too loose.
The one single, big problem is the pre-load applied to these bearing at manufacture (and in the first iteration of the workshop manual - by workshops).
Zero pre-load - no problem for life unless the rider hits a big pot-hole or whatever. The damage is done by axial impacts, nothing more, nothing less.
This is not a mod I would bother with or give a second thought to.
issues and considerations are correct ask
but the effects of a lack of grease is that the bearings do not rotate on themselves
This brings you always work the same points
plus completely dry and this leads to friction direct metal to metal
if there is a lot of grease bearings has a small chance to turn a minimum on itself as it works
This allows distributed in better way the effort on the material surface
There is still a fact
before making changes to my gilera had serious steering problems.
I was convinced of need to change the bearings.
the change was the last desperate effort before spending more than EUR 350 from mechanical
It worked ,Gilera with grease bearing now work as a new one
I can not be sure it is the definitive solution but for now it worked
I'm trying to understand if an accurate lubrication can be a definitive solution of the problem
It's possible but this response can only give me the time and distance
with this change I have the means to keep these verification in easy ceap and cleanly way
