2001 ET4
2001 ET4
So i have already asked for parts that were damaged. I received them and installed them (thanks sean). This scooter still wont take any throttle. It idles a LOW rpms, but as soon as any throttle is applied it begins to surge and sputter. Mixture screws do nothing full throttle or no throttle. i have cleaned the carb many of times. float level is right. Jets are clean. i have removed the vacuum line to the carbon box as is referenced in ET4 rough starting. i have reconnected it. the spark plug is brand new. i have used a SMALL car battery to start it in the past and it surges still, have i ruined something?
I guess my next question is a timing trigger damaged or something of this sort? the choke also might be in question but it seems like the bike starts and idles!?
PLEASE HELP haha!
-Chris
@-bill- avatar
Vespa ET2, Scarabeo 500 GT
@-bill- avatar
Did you check/clean/replace the air filter?
@brett avatar
P200
@brett avatar
P200
Try using your master key.
If that works, reprogram your blue key.
[ Time: 0.0228s ][ Queries: 3 (0.0015s) ][ Debug on ][ 309 ][ Thing One ]
