@bucret avatar
150S, 01 Indian Centennial Scout LE
@bucret avatar
do you have to balance the tires on a S150?
@vezpa avatar
@vezpa avatar
Ideally yes but (generally) the 150 doesn't go fast enough to really require it unless the tire is extremely out of balance. I have NEVER seen this as an issue on the 150s with a decent tire. Usually speeds over 65 mph is where you need to be worried about balancing. If you ride it and it feels OK no problem. On a side note front tire balance is usually more important than rear.
@tomjasz avatar
Grievance Farmer
Grievance Farmer
@tomjasz avatar
Re: question about tires
No
@bucret avatar
@bucret avatar
thanks, just wanted to make sure.
[ Time: 0.0096s ][ Queries: 3 (0.0015s) ][ live ][ 334 ][ ThingOne ]
