Run it to the corners at the top. The angle is small enough that you can grind the parts as though they would be installed straight.
Wiki Moderator
![]() LX 190, Aurora Blue + Stella FOUR STROKE FURY! + '87 Helix
Posts: 6916 Location: Los Angeles |
jess wrote: Tested for the first time on the way into work today. There's still too much flex in it, and is thus fairly susceptible to vibration. The video ended up fairly jello-y. I'm thinking about putting the top corners under tension, using some strong cord to pull the corners toward the anchor behind the seat. If that doesn't work, I'll have to consider welding in some more bracing. In the end, mounting the camera to me gave me the best vibration absorption... and the worst aim. Eventually, I'll move up to a camera with image stabilization and hope that helps. |
![]() UTC
Posts: 22857 Location: Harriman, Tennessee, Tn |
ericalm wrote: jess wrote: Tested for the first time on the way into work today. There's still too much flex in it, and is thus fairly susceptible to vibration. The video ended up fairly jello-y. I'm thinking about putting the top corners under tension, using some strong cord to pull the corners toward the anchor behind the seat. If that doesn't work, I'll have to consider welding in some more bracing. In the end, mounting the camera to me gave me the best vibration absorption... and the worst aim. Eventually, I'll move up to a camera with image stabilization and hope that helps. |
oopsclunkthud wrote: Reclining Oscillation Control by Kinetic H-infinity Optimization resulting in Push Pull Energy Reduction |
![]() UTC
Moderatus Rana
MP3 250 and 2 MP3 500s
Posts: 22659 Location: Nashville, Indiana |
Moderatus Rana
![]() MP3 250 and 2 MP3 500s
That is a cool camera angle. Worth the work you are doing. Now you got me thinking about how to do something similar on my mp3
Maybe you can suspend the camera from that top bar and use a heavy weight on the camera for a ballast to keep it steady.
IBKING |
![]() Looking for the next one, probably electric
Posts: 3690 Location: Babcock Ranch, Florida |
Jess, that video was less jerky than I was envisioning. Generally I find that rubber bushings and bungees won't do much for large amplitude shaking, but a couple of bungees led forward might do the trick for you. Maybe the large black rubber truck tie downs.
![]() 2016 GTS 300 Super - red, of course.
Posts: 4755 Location: Hertford, North Carolina |
Jess, could you simply mount the camera on a front rack? (Or clamp it to the leg shield).
Would not be over the shoulder but you probably could see the view screen whilst riding and maybe reach the controls without turning around. |
Raputtak wrote: Jess, could you simply mount the camera on a front rack? (Or clamp it to the leg shield). Would not be over the shoulder but you probably could see the view screen whilst riding and maybe reach the controls without turning around. But that's not really the point. What I'm trying to do here is raise the bar (so to speak) for scooter video. I want stunning video quality. I want composition. I want context. I want something that transcends the pedestrian front-shot scene (which I find tedious and unexciting) to become art. Lofty goals, to be sure. And I'm likely to fail. But I'm going to have fun failing. Here's inspiration: ⚠️ Last edited by jess on UTC; edited 1 time
Love the inspiration, love the Coldplay soundtrack. I can see exactly where you're coming from. And from the two lots of footage I've already seen, you're getting close. Hope you get it sorted by the weekend!
![]() UTC
Daring Plum GT 200, Dragon Red LX 150, Kawi Green KLR 650, Hi-Viz Yeller V-Strom 650, Bonneville Black
Posts: 634 Location: Honolulu |
![]() Daring Plum GT 200, Dragon Red LX 150, Kawi Green KLR 650, Hi-Viz Yeller V-Strom 650, Bonneville Black
Run a bungee from the bag hook to the top of the camera rig and call it done.
Myself, I'd just screw a RAM mount to the top of an old helmet. ![]() |
jess wrote: I want composition. I want context. I want something that transcends the pedestrian front-shot scene (which I find tedious and unexciting) to become art. Quote: I could have been a contender. Just curious (see, you have got me all involved now) what camera are you planning on using? Does it have that 'anti-shake' feature? (I guess it must. they all do today). OK, multiple cameras, edit the shots together, sound track (to capture the screams of innocent bystanders), How about footage of the tire hitting the road? (Like they show on "Top Gear"). Stop me someone, before I go crazy here. BTW, how does one do a wheelie with a CVT bike? Hang onto the rear brake, rev it up, release the brake and yank the handlebars up and back? Then say hi to the nice EMT person... Never mind. |
Raputtak wrote: Just curious (see, you have got me all involved now) what camera are you planning on using? Does it have that 'anti-shake' feature? Needs to be more rigid. |
Wiki Moderator
old as dirt wrote: helmet cams |
Update: glasseye and I did some creative knotting of the rig to put the corners under tension. In theory, this should lessen the vibration out at the ends. In practice, it's not enough of an improvement.
Looks like I'm going to be doing some welding tonight. ![]() ![]() ![]() |
jess wrote: Raputtak wrote: Jess, could you simply mount the camera on a front rack? (Or clamp it to the leg shield). Would not be over the shoulder but you probably could see the view screen whilst riding and maybe reach the controls without turning around. But that's not really the point. What I'm trying to do here is raise the bar (so to speak) for scooter video. I want stunning video quality. I want composition. I want context. I want something that transcends the pedestrian front-shot scene (which I find tedious and unexciting) to become art. Lofty goals, to be sure. And I'm likely to fail. But I'm going to have fun failing. Here's inspiration: |
![]() Jess - You may have inadvertently answered the question of how to carry a canoe on a scooter with that rig. Sorry the ropes didn't work out and hopefully the welding won't be too much. Have you considered emailing the author of the video you posted (Pashnit?) and asked how he set his rig up? It won't help with the immediate future but perhaps you can get some additional ideas for later? |
![]() UTC
04 GT200 & 2005 PX150(sold), 2005 Bajaj Tuktuk
Posts: 1759 Location: pa |
![]() 04 GT200 & 2005 PX150(sold), 2005 Bajaj Tuktuk
![]() UTC
ericalm wrote: old as dirt wrote: helmet cams |
Having more than 50mm of suspension travel would probably help.
After making it as ridged as possible, if it's still an issue, we can create a mount for the camera that damps out the rest. Just not before Saturday. |
![]() UTC
2012 BV 350
Posts: 2091 Location: Vestavia Hills, AL |
Have you tried foam between the camera and the tripod mount/base? I've taken some foam off of foam paint brushes and placed them at different points of the mounts (where the ram mount attaches to the mirror and at both ends of the arm). I perceived less vibration with the foam used at the mirror and the arm ends, but have yet to test the foam on the tripod mount/base; I'm also thinking of using velcro at this point.
Just received a Manfrotto Magic Arm this evening. Did some quick test footage before the light was totally gone -- stand by, uploading.
RIP
Okay, here's the first video. This is a low-down shot near the exhaust. It looks like it's going to scrape the ground in places, but it's really got quite a bit of clearance before it does.
There's still some bounciness going on, but this really isn't bad. |
Second video being uploaded now...
EDIT: Dammit. I selected HD for the second one, and so now it's going to take half an hour to upload. |
![]() GTS, LX, VSD, VSX, VNX, LD 125, Chucky, LI125
Posts: 4181 Location: San Jose CA |
![]() 2009 GTV250 (Gone), 2003 Inder trailer (also gone), 2001 BMW R1100RT
Posts: 5707 Location: Santa Cruz California |
It was quite clear. There's probably some software that could take out the remaining bounce. It was interesting to see the suspension in action. The sound was quite muffled but I'm glad it was there. It add s a dimension to the vid that is lacking when not there (play it w and w/o the sound).
Best Miguel |
Miguel wrote: It was quite clear. There's probably some software that could take out the remaining bounce. It was interesting to see the suspension in action. The sound was quite muffled but I'm glad it was there. It add s a dimension to the vid that is lacking when not there (play it w and w/o the sound). |
Okay, next video. This one is in HD, which you can watch full-size if you view it on youtube.com (instead of here in this little tiny window).
I think this video was bumpier than it actually should have been -- when I got home, I found that one of the screws on the Manfrotto arm-end had come loose, and the whole thing was moving around WRT the clamp. The key thing with the Manfrotto Magic Arm seems to be how much meat it's holding onto. On the puny little square tubing I've built this rig out of, there's quite a bit of movement of the clamp itself, because it doesn't have enough surface area to really clamp down. Clamped to a table, on the other hand, this thing is rock solid. Surprisingly so. I'm thinking that if I weld some heavier square tubing to this rack somehow, I can have a good place to clamp. And since the Magic Arm is just as long as the length from the middle crossbar to the top, I could just cut the whole top of the thing off and be done. EDIT: forgot to add the video! |
![]() Kymco P250 Now, P200E in the 80's
Posts: 3908 Location: Antelope, CA, USA |
Great efforts! The second one looks good but based on the noises, the mount sounds like its adding more than its share. Also, cutting off all the tall stuff will remove most of the movement in the rack as a whole.
Tim at Pashnit is local to you in NorCal and you might see if you can't but him a cold beverage and pick his brain. |
TechGuy wrote: Great efforts! The second one looks good but based on the noises, the mount sounds like its adding more than its share. TechGuy wrote: Tim at Pashnit is local to you in NorCal and you might see if you can't but him a cold beverage and pick his brain. |
Then it looks like you are well on your way. Looking forward to seeing more videos.
Keep up the good work. |
RIP
Jess, The angle and video quality is fantastic mate.
When i first started reading this thread i wondered what you were up to? I though you had built a monster motor for the Land speed trials..... are you going? Cheers |
That looked really good. The image of the passing landscape was steadier than the visible scoot or yourself.
(Although I fell puking on the floor after that little serpentine weave you did ![]() |
jimh wrote: I though you had built a monster motor for the Land speed trials..... are you going? |
