I have a 2001 and 2002 ET2, both with about 1000 miles. Gently used, but used often (every weekend) from May to October. As both started to develop starting issues, I replaced the fuel tap assemblies. Didn't help. Suffered through last year and this spring I figured it was a fine time for tune ups and also to upgrade the carb and muffler. I picked up the proper 17.5 mm carb for this scooter (the Euro Malossi) and the Sito +. Professionally installed by a Vespa dealer, but we are still having starting problems.
The dealer has attempted to replicate the problem, but states that they have no trouble at all starting / running the scooters. They returned the scooters again about a week ago and we went to use them this weekend and the same problem happened.
Key in, crank the engine and nothing but starter. Twist a little on the gas, and after a few attempts almost a firing of the engine. A few more twists and a few more sputters. Keep this up for 5 minutes and eventually you can coax the thing to start. Once started, you have to tease the throttle - too much throttle and it dies. But once warmed up, runs like a top. It's like the choke isn't working and you have to start it without the benefit of choke - or that the fuel isn't running and it takes forever to get it to flow.
The irony here is the one that was worse before the tune ups / carb change is now running fairly well, while the other that was running fine is now suffering from these issues.
I'm open to any and all solutions, including returning everything to bone stock (ie: Put back the 12mm carb and original mufflers).
Any advice? Thanks!
