kilted texan wrote:
Silver Streak wrote:
How old is the battery?
2006 it is the OEM battery.
Getting old! Being a 2006, it may be one of the smaller, unsealed batteries which that were marginal to begin with. I'm not really familiar with the battery history of the GT200, but on the LX -- late that year or the next -- Piaggio switched to the YTX12bs sealed battery, which is the largest that will fit in the well, is maintenance-free, and has a higher output. My 2007 LX150 came with the YTX12bs, and even it had gotten weak enough that I had to replace it last year. Scooters are harder on batteries than cars because the less-robust charging system keeps them cycling deeper and more often than car batteries.
Your belt is getting close to the end of its reliable life as well. May as well change it if you wind up having to get into the tranny. You don't want it failing at 60+ mph on the highway, as it could possibly lock up the rear wheel.
