@manypearls avatar
'08 GT 200
@manypearls avatar
'08 GT 200
Hey
My GT200 has started something new, which only happens when it is very hot. When starting out under a lot of torque
(up hill, or with a passenger) I get a rumbling sound from by the transmission.
The bike only has about 2400 miles, not near time for a new belt. Maybe it's just loose?
What should I check for, or don't bother and bring it to the overpriced Vespa dealer who will probably fix it correctly.
BTW, no longer under Vespa warranty.
THANKS
s. pearl
@papa_smurf avatar
GTS250ie, ET4
@papa_smurf avatar
GTS250ie, ET4
sounds like dust in the clutch bell
@manypearls avatar
'08 GT 200
@manypearls avatar
'08 GT 200
OK, I've heard of that. Is this where I have to open the cover, smooth out the clutch surface, and remove any material in there?
@starreem avatar
@starreem avatar
Some folks have success with just removing the shiny Vespa badge on the transmission cover and spraying in the small holes, either brake cleaner, or just compressed air while turing the rear tire.
@manypearls avatar
'08 GT 200
@manypearls avatar
'08 GT 200
Thanks.
Would I use compressed air from like a computer dusting can, or from a gas station tire pump?
@oopsclunkthud avatar
3:5
manypearls wrote:
Thanks.
Any of the above would likely work.
@manypearls avatar
'08 GT 200
@manypearls avatar
'08 GT 200
This forum is great!
oopsclunkthud wrote:
manypearls wrote:
Thanks.
And if it doesn't, you may indeed need to check if the belt is worn
Mine have been going about that quickly
due to the heat and a lot of stop & go (around town) riding
I doubt that the volume of air from a can of computer air spray would do the trick. Then again you often can't find the right nozzle at your average gas station either.
Could be wherever you take your car for service, assuming you have one, would air-blast the area for you. Then hit it with the brake cleaner using the small tube to get up inside there.
@boulty avatar
Moderator Australis
2014 Moto Guzzi V7 Stone, 2014 Vespa 150 Primavera (sold) 2003 Vespa GT200 (sold)
Moderator Australis
@boulty avatar
Yes, this is common and yes it happens more often in hotter weather. The fix is pretty easy and there are pics in the Wiki on how to remove the transmission cover. There are alternatives without cover removal.
Try a search on 'Clutch grind', there are many many posts.
Here's some info from a while back...
GT200 Grrrr-inding noise
Boulty wrote:
Hi Alice
The latest development on this front was from Gary ' Addicted'.
The $10 solution is an absolute winner and I have just had a 'shudder free' month following his advice.
The answer is a can of 'Brakleen'.
It works brilliantly!!!!!!!!!!!!!!
Am I really burning through belts? (Post 88790)
Good luck.
[ Time: 0.0202s ][ Queries: 4 (0.0105s) ][ live ][ 329 ][ ThingOne ]
