@astromags avatar
@astromags avatar
I'm wondering if new, stiffer shocks will make my ride seem less squirrely. I'm kinda all over the place when I hit a bump. Pretty scary at high speeds.
Do I need new shocks?
@shawn45 avatar
1979 P125x, 1980 P200E
@shawn45 avatar
getting lots of bounce, bottoming out, or lots of movement side to side like the rear end is coming out from under you?
@jeremy_w avatar
79 P200e, 81 100 Sport
@jeremy_w avatar
A new set of stock shocks should stiffen you up (ha!)
Also, could be worn out motor mounts - the Clauss Studios ones are supposed to tighten up your ride.
@astromags avatar
@astromags avatar
Haven't bottomed out yet, I don't think, But definitely feels like the rear end is moving side to side.
Motor mounts seem to be okay.
@gatekeep avatar
1974 Rally USA 200 1980 P200e
@gatekeep avatar
How many miles on your ride? New mounts really make a difference if you've been bouncing around on smoochy rubber. As far as the Claus mounts go I've heard stock mounts are as good. The Claus are really stiff. I had a choice to go with those or stock I choose stock for my Rally.
@koenig_blues avatar
+1 i'll go for stock too
@jamesjohn avatar
1970 Vespa Rally 180
@jamesjohn avatar
check your tire pressure first.
@cuba avatar
Vespa Cosa 200, GTV 250
@cuba avatar
new silent rubbers and stiffer shocks will do just fine.
but new rubbers are a must.
my rear wheel bended to the right and rubs against the shock
due to cracked right silent rubber.
@t5bitza69 avatar
T5s
@t5bitza69 avatar
T5s
badunkadunk
a clauss shock mount stiffened my arse External inline image provided by member with no explanatory text .... that along with a lml full length rear shocker but you have to cut an extension bolt to connect them all together
but i can close to knee down in corners
@nola_john avatar
GTS, PX125E, P200
@nola_john avatar
GTS, PX125E, P200
I like my Clauss mounts and my SIP shock. Solid as a rock.
anyone used this before?
http://www.hotrodscooters.com/products.htm
@astromags avatar
@astromags avatar
It's got about 4100 miles on.
Tires are good.
@astromags avatar
@astromags avatar
...and what is "silent rubber"? I'm not familiar with that term.
px200
px200
Hello
Silent Block usually means a rubber block sandwiched between steel, put your bike on the stand and lift the rear end if the engine stays on the floor supect the block has seperated or the shock has come unscrewed.
This is a common occurence with the rear shock and is an easy fix.
I have seen bikes where the block has seperated still being ridden.
Grumpy
@quasi-moto avatar
SawStop
@quasi-moto avatar
SawStop
The Clauss mount gives you a much better ride, it took the lateral motion totally out of a P series scoot I had. I would do it again in a heartbeat.
[ Time: 0.0180s ][ Queries: 3 (0.0088s) ][ live ][ 327 ][ ThingOne ]
